Old 01-13-2012, 09:35 PM   #1
BCOWANWHEELS
Th400 and hi-hump question
If I change over from a th350 (low hump) to a th400 in my 1970 lwb do I have to install the high hump in the floor ? i sure would hate to cut my floor board. thanks for the help
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 01-13-2012, 09:45 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Th400 and hi-hump question
Small block....NO! my 69 came from the factory with a low hump (350/400 turbo). The BB trucks are a different story tho.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-13-2012, 09:47 PM   #3
BCOWANWHEELS
so with my 350 sbc a th400 wont fit without installing a hi-hump right ?
Old 01-13-2012, 10:11 PM   #4
FirstOwner69
FirstOwner69's Avatar
No problem putting a TH400/350 V8 combo in a truck with a small hump. My 69 came that way as Crazy Longhorn said his did.
FirstOwner69 is offline   Reply With Quote
Old 01-13-2012, 10:13 PM   #5
BCOWANWHEELS
thanks fellas I sure didnt want to cut my truck floorboard out.
bob
Old 01-13-2012, 11:45 PM   #6
Beat68CST
Beat68CST's Avatar
You can fit a BBC and a 400 on a low hump.
You can fit a Cummins and a 47RH under a low hump too (;
Beat68CST is offline   Reply With Quote
Old 01-14-2012, 01:15 AM   #7
BCOWANWHEELS
i also have a cummins 4bt with a A518 I was thinking about for a future truck.
Old 01-14-2012, 01:39 AM   #8
Beat68CST
Beat68CST's Avatar
You have to cut the main crossmember and flatten it out to about only 2 1/2 inches tall so you can get the motor to sit flat
Old 01-14-2012, 01:45 AM   #9
BCOWANWHEELS
Beat68cst,
you dont have to do this with sbc and th400 swap do you ?
Old 01-14-2012, 02:01 AM   #10
Beat68CST
Beat68CST's Avatar
Nooo, SBC and T400 fit perfect. Everything will clear nicely.
You can shoe horn a BBC and T400 under a low hump too.
Old 01-14-2012, 11:09 AM   #11
DaHos
DaHos's Avatar
Anyone have clearance photos of the BB and th400 with low hump? Only issue I can see is the longer tail shaft.
DaHos is offline   Reply With Quote
Old 01-14-2012, 08:05 PM   #12
BCOWANWHEELS
Theres plenty of room for the longer tailshaft in fact you could run the longest tail shaft trans and possiblt run a 1 piece drive shaft. I have a gear vendors o.d. Going behind my th400 in my 1970 truck and a 1 piece shaft with 1350 joints is the route i,am going.
Thread Tools
Display Modes
