01-15-2012, 12:08 PM | #1 |
PB Dropmember, Power Steering, LS Motor. Question...
Hello, i have a quick question for anyone out there that has been down this road all ready. I have a 85 C30 with a 5.3L LS swap. Im installing a porterbuilt dropmember in it, with the power rack from unisteer.
Can anyone tell me if this kit here from jegs : http://www.jegs.com/i/Borgeson/153/925102/10002/-1 Is the kit i need to adapt my unisteer rack that i have on my dropmember to my LS motors power steering pump? I have searched locally and all my local shops cannot get me the fitting i need to seat into my unisteer rack, then i came across this one and wonder if its the one i need. If anyone has any others that work as well, i would love to see what your using. Thanks Taylor
Oops! |
01-15-2012, 12:20 PM | #2 |
67-72 parts collector,…
Re: PB Dropmember, Power Steering, LS Motor. Question...
I ordered my 6AN fittings directly from Unisteer.
http://www.unisteer.com/search_by_pr..._fittings.html
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-15-2012 at 12:26 PM. |
01-15-2012, 02:55 PM | #3 |
I got mine from nathan and it worked perfect. The rack fittings are metric I believe. The SAE thread fitting will screw in but it is going to leak. Nathans price was not bad and you know it will work.
01-15-2012, 03:05 PM | #4 |
My rack had standard threads.
5/8" on the return line. 9/16" on the pressure line.
01-15-2012, 03:27 PM | #5 |
I purchased all my dropmember components from nathan, when we got to plumbing the power steering the kit came with four fittings. I believe that two of the fittings were standard and two were metric. I am running a unisteer rack and after a discussion with nathan the fittings were metric if a recall correctly. Hopefully nathan will chime in and clarify. The standard fittings will thread in but I think nathan had some issues with them leaking.
01-15-2012, 03:56 PM | #6 | |
My rack didn't have inverted flare threads. This is the fittings I just recieved from Unisteer. http://www.unisteer.com/search_by_pr..._fittings.html I'm running braided TFE hose with 6AN fittings.
01-15-2012, 04:17 PM | #7 |
You are correct lolife, I found the thread about it and it clarifies it. I knew there were some confusion about the metric and I had it bassakwards.
http://67-72chevytrucks.com/vboard/s....php?p=4452201 Last edited by texastrendz; 01-15-2012 at 04:18 PM. Reason: spelling error |
01-15-2012, 06:42 PM | #8 |
Yea, nobody around here has the damn standard fittings. Everyone only has the metric stuff.
I will get a hold of nathan and get the hoses i need. Thanks for the replies people!!
Oops! |
01-16-2012, 03:19 AM | #9 |
We would love some pictures of the truck when your done with it.
Thread Tools | |
Display Modes | |
