Old 01-16-2012, 04:31 PM   #1
redledsled
Small Block with Big Block Exhaust?
Hi everyone,
I have a '65 C20 which used to have a 454. The previous owner kept the engine, but left the brand new exhaust system. I'm looking to drop in a 350 and would like to use the exhaust if I can, but I'm not sure if there are any exhaust manifolds or headers for a small block that will bolt up right. Any ideas? Thank you a lot.
redledsled is offline   Reply With Quote
Old 01-16-2012, 05:27 PM   #2
Heater63
Heater63's Avatar
Re: Small Block with Big Block Exhaust?
you're correct; it will not be a bolt together piece of cake. Once your engine is in, with either cast manifolds or headers, you will have to have a muffler shop connect to the existing exhaust pipes. But, that's minor, it sounds like most of your system will be able to stay the same, probably from the firewall back won't need to be changed.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-16-2012, 07:51 PM   #3
redledsled
Thank you. Do you think I'd be able to use stock manifolds for this? Any idea how much it would cost?
Old 01-17-2012, 01:10 AM   #4
Captainfab
60-66 Nut
What manifolds or which headers to use will partially depend on what transmission you will be running.
Old 01-17-2012, 03:13 AM   #5
redledsled
I'm running the original 4-Speed if that helps. Man, I wish I had a camera.
Old 01-17-2012, 02:50 PM   #6
Heater63
Heater63's Avatar
manuals are smaller than auto's, so it should be easier. You need to go talk to your local muffler shop now, they will have to make the "connection" your going to need.
292 + TKO500
Old 01-18-2012, 12:16 AM   #7
redledsled
Sweet, thanks for your help!
Old 01-18-2012, 01:29 AM   #8
Captainfab
60-66 Nut
Then you're going to have to be careful which manifolds or headers you choose. Not all of them will work with a manual trans in these trucks. Namely, clearing the clutch bellcrank.
Old 01-18-2012, 03:53 AM   #9
argonaut
argonaut's Avatar
Or you can go with a hydraulic clutch actuator...
Any good exhaust shop should be able to make the modification pretty quickly and easily. You may need some new flanges depending on what manifold or header you use and what was used before.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 01-19-2012, 05:22 PM   #10
redledsled
I found out that the 454 used headers if that helps. I'd like a hydraulic actuator, but I don't have too much money for a month or so.
Old 01-20-2012, 01:45 AM   #11
Captainfab
60-66 Nut
Since the exhaust for the 454 was setup for headers, it would be easier to hook up to the small block if you used headers again.
Thread Tools
Display Modes
