Old 01-17-2012, 12:28 AM   #1
cstm68
cstm68's Avatar
door question
is there a difference in doos on blazers between years or double wall or single wall tops??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 01-17-2012, 12:56 AM   #2
YBNORML
YBNORML's Avatar
Re: door question
The only diference that I am aware of is the '72 doors have a screw tying the wing windows together. Other than that I do not believe there is any diference.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-17-2012, 02:31 AM   #3
cstm68
cstm68's Avatar
Re: door question
ive seen some ware the top of the door frame is different ware it meets the wing window
Old 01-17-2012, 02:34 AM   #4
YBNORML
YBNORML's Avatar
Re: door question
That would be news to me. I have never noticed any diference but hey, I learn new things everyday.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 01-17-2012, 12:10 PM   #5
71RestoRod
71RestoRod's Avatar
Re: door question
Only difference I know of at the top of the door frame is the early and late style plastic caps. The late style (72 I think) are designed to be used with the drain guards. Earlier ones are smooth and a little shorter in profile. Only one style is reproduced (later I think). Might also coincide with single and double wall tops but I don't know for sure.
Something else to keep in mind is that early (69-70) and late (71-72) doors have different style (sport) mirrors and the holes are drilled in a different location so don't assume that all the mounting holes are in the right place!
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 01-17-2012, 12:41 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: door question
I've never heard about a difference in door caps. The only difference I know of is the screw that YBNORML mentioned.
The window seals on the top are different for double vs. single wall.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-17-2012, 01:24 PM   #7
cleszkie
cleszkie's Avatar
Re: door question
71RestoRod is correct about the plastic door caps.
cleszkie is offline   Reply With Quote
Old 01-17-2012, 01:39 PM   #8
YBNORML
YBNORML's Avatar
Re: door question
I had no idea about the caps either.
I was aware of the window mounting locations though.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Thread Tools
Display Modes
