Old 01-19-2012, 08:34 AM   #1
jcloud6
Questions about SBC 350 build up
I just finished putting my 350 back together, but don't have access to a dyno. Based on this information, and your experience can any anyone give me a ball park figure of how much horse power the engine is going produce.
1970 350 4-bolt main stock block bore 0.30 over
Flat top pistions
Compression 10.5:1
Vortec Heads casting #12558062 (stock)
Comp Thumpr cam CS 279T H-107 Duration @.006 tappet lift 279/297 Gross valve Lift 479/465
power range (2000-5800)
Edelbrock Vortec High Rise Air gap Intake P/N 7516 power range (1500-6500)
Street Avenger Holley 670 cfm carb
Accel performance distributor w/ HEI super coil
Thanks for any feedback or recommendations you can provide
jcloud6 is offline   Reply With Quote
Old 01-19-2012, 04:19 PM   #2
OleBlue79
OleBlue79's Avatar
Re: Questions about SBC 350 build up
Probably in the 375 to 400 HP neighborhood. Just my guess...
79 C-20 Scottsdale 350/400 3:73 gears 9 leafs and a headache rack (I speak English, thank you)
OleBlue79 is offline   Reply With Quote
Old 01-19-2012, 06:38 PM   #3
Stepper562
Stepper562's Avatar
I'd say 25 less then above estimate...350-360.
Stepper562 is offline   Reply With Quote
Old 01-19-2012, 08:11 PM   #4
djunkie
djunkie's Avatar
That'd be my guess also. Probably right about 350hp.
djunkie is offline   Reply With Quote
Old 01-19-2012, 08:13 PM   #5
ringger14
ringger14's Avatar
Comp cams has a cam selector tool. You can enter your info and itll give you its best estimate.
ringger14 is offline   Reply With Quote
Old 01-19-2012, 10:20 PM   #6
OleBlue79
OleBlue79's Avatar
Headers?
Old 01-20-2012, 06:44 AM   #7
jcloud6
Thanks guys for the feedback, that's information I was looking for. To gain a few more horse power, It has been suggested that I port match the vortec 062 heads and select a different cam that will work in sync with other components. I failed to mention the 1-1/2 tube header in the initial thread.
Old 01-20-2012, 08:30 AM   #8
xrcr
I have a real close setup to this,similar cam numbers, same carb, 882 heads which dropped my compression I'd think and a weiand open plenum. I port matched intake and exhaust and we're going with 350hp
xrcr is offline   Reply With Quote
Thread Tools
Display Modes
