Old 01-20-2012, 04:50 PM   #1
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
1960 grill on 63-66
Ive been thinking about putting a 60 grill on my 63 because I like the dual headlights and want to put yellow lights in the high beams. Has anyone done this? Im just wondering if by chance the mounting holes would line up.
Harley1650 is offline   Reply With Quote
Old 01-20-2012, 04:59 PM   #2
1963c-10
1963c-10's Avatar
Re: 1960 grill on 63-66
Mounting holes on a 63 grill support are different, but the holes could be drilled to except the 60 grill. The 63 grill had 4 mounting locations per side. The 60-61 shared the same grill support, 62 had its own, 63 had its own and 64-66 was the same. The grill supports all look the same and will interchange, but have different mounting locations. GMC ran a dual headlight grill I believe through 66. Although the 60-61 grills differ from the GMC grill, this will get you close to what your looking for. And of course you'll have to do some wiring.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-20-2012, 05:01 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I had a 61 grill in my 65. I would think it would just bolt up. You could Tee off the high beam side of the main headlights for the brights.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-20-2012, 06:09 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: 1960 grill on 63-66
1960 on a '63
http://67-72chevytrucks.com/vboard/s...d.php?t=332410
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-20-2012, 07:22 PM   #5
62 Longbed
62 Longbed's Avatar
I put a 1960 Grill in my 62 pickup . Had it sand blasted and powdercoated , bought the new headlamp wire harness , halogen lamps , plugged it in and looks and works Great !!! I didn't need to drill any holes in mine that I remember .. Just finished doing the Grill letters , 1st picture shows the lettering after I finished ... I as well thought about the amber inner headlight / driving lights ...
62 Longbed is offline   Reply With Quote
Old 01-20-2012, 07:27 PM   #6
blackmopar
63 C10 has it right - you need to drill extra holes to mount but its cake
Im a def fan of the earlier dual light grille!
blackmopar is offline   Reply With Quote
Old 01-20-2012, 07:32 PM   #7
losthope
losthope's Avatar
"glendale" a member here was going to do the same thing with the yellow/amber fog lights on the center lights but ended up selling his truck and the extra dual headlight grill before we had the chance to do it....i thought it was a cool idea but never got to see it completed....if you do it i would be interested in seeing a picture of how it comes out.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 01-20-2012, 07:38 PM   #8
blackmopar
no to hijack (the amber light idea sounds cool btw) but does anybopdy know if the dual headlights take more juice to luminate?
I mighta just wired wrong but I wanted all lights on all the time so I just piggybacked the low and high beam wiring to all 4 lights - but now my low beams (all 4 lit up) are like a soft white light buld - kinda yellowish and dont put out any amount of light to see at night with - although my high beams are bright as heck........
Old 01-20-2012, 07:53 PM   #9
FreakyMalo
FreakyMalo's Avatar
blackmopar- Check the grounds on your low beams. Also, you might think about doing a relay setup for those lights. You're running all that amperage from the battery up to the headlight switch and back out to the lights. There are a few good threads on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=397695
You'll end up with brighter lights and a much lower electrical load on your headlight switch.
I don't know squat about mounting the grille but I do prefer the quad lights. Using a GMC grill and hood on my '66 Sub.
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 01-20-2012, 07:55 PM   #10
blackmopar
i'll check gnd again - ive got em on relays thx
Old 01-20-2012, 11:07 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
A 4 lamp system shouldn’t draw any more power than a 2 lamp system. The low beam bulbs in a 4 lamp system actually have 2 filaments, normal low beam and an even dimmer filament, which illuminates like a marker lamp when the circuit is switched to high beams. The inboard high beam lamps only have 1 high power filament.
When the 4 lamp system is switched to high beams, the normal low beam filament in the low beam bulbs go out and power is switched to the dim filament, resulting in power output similar to a 2 lamp system - the high beam lamps providing almost all of the primary light.
If you’re having wiring problems beyond the grounds, the diagram on this post may help. There’s also information on how to keep the low beam bulbs on full power when switching to high beams:
http://67-72chevytrucks.com/vboard/s...d.php?t=387693
Old 01-21-2012, 06:58 AM   #12
Harley1650
Harley1650's Avatar
Ok, sounds like a piece of cake. Just have to find a grill, Thanks everyone, I'll post pics when I get it done.
Thread Tools
Display Modes
