Old 01-20-2012, 08:43 PM   #1
irishmil
Vin Number help
Need a little help.
Looking at purchasing a 1966 C10 Stepside
The metal tag on the door reads:
chev. od
bid
c144 c66157
vin# 6Z17xxxx
Does any of this makes sense?
I know the c144 means 1/2 ton step-side
The rest?
Thank you for your time
irishmil is offline   Reply With Quote
Old 01-21-2012, 10:23 AM   #2
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: Vin Number help
if I understand correctly, the numbers 6Z17xxxx mean
6 for 1966
Z for assembled in Fremont (CA I believe)
17xxxx means the 7x,xxx unit built that year at that plant
on my truck the VIN looks like (using your #'s):
c1446Z17xxxx
the tag is on the cab door frame above the door, not the door
Larry
fleetsidelarry is offline   Reply With Quote
Old 01-21-2012, 11:16 AM   #3
yelmer
Re: Vin Number help
yes that is a 1/2 ton the 6 is 1966 the z is fremont assembly plant the rest of the number is the production number they all start with 1 then the rest is the number made at that plant . example 177193 would be the 77193 truck built at that plant that year . if you have the full number i can give you what month your truck was built in mike
yelmer is offline   Reply With Quote
Old 01-21-2012, 11:21 AM   #4
irishmil
Re: Vin Number help
Great information...Thank you the full number is 174940
Thank you
Old 01-21-2012, 11:25 AM   #5
yelmer
Re: Vin Number help
your truck was built in june 1966
Old 01-21-2012, 11:47 AM   #6
irishmil
Re: Vin Number help
Thank you for the information again
Old 01-21-2012, 03:34 PM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Vin Number help
Vin Number query
http://67-72chevytrucks.com/vboard/s...d.php?t=402078
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-21-2012, 08:14 PM   #8
LT1 Burb
LT1 Burb's Avatar
Re: Vin Number help
I just looked at a 66 truck with vin C144 C-6-177 with a 6Z156681 and it is a stepside but I didn't think t you could decode the vin to the bed. IE is there really a way to tell if it was fleetside or stepside.
LT1 Burb is offline   Reply With Quote
Old 01-21-2012, 11:00 PM   #9
yelmer
Re: Vin Number help
yes you can c1404 is stepside short c1504 longbox both 2 wheel drive c1434 short fleetside c1534 longbox fleetside these are all 1/2 ton trucks mike
Old 01-21-2012, 11:30 PM   #10
LT1 Burb
LT1 Burb's Avatar
Re: Vin Number help
WHat does the one above decode as, also my longbed fleetside is a C1545Z and it is a 65 but I don't see how that decodes either, other than it is a 127" wheel base but what is the 45, in my book it doesn't jive.
Old 01-22-2012, 10:11 AM   #11
fleetsidelarry
Senior Car Nut
Re: Vin Number help
C15=1/2 ton, 127 wb
4=stepside
5=1965
Z=Fremont
I have the same problem with my '66 Fleetside, which codes as a stepside
EDIT: I just checked my '65 Fleetside, which also codes as a stepside. so either I'm reading my assembly manual wrong or the manual is wrong.
or, both had the beds swapped at some point. I would guess that a factory mismatch would not have been unheard of
2nd EDIT: post #4 on this link makes more sense (from the links 1Bad62Pro/Steet supplied)
Larry
Old 01-22-2012, 10:26 AM   #12
yelmer
Re: Vin Number help
did you look at the buildsheet if it is still there behind the seat ? that might give some clues? it might be a special order truck . i will look at some other stuff i have mike
Old 01-22-2012, 10:44 AM   #13
fleetsidelarry
Senior Car Nut
Re: Vin Number help
sorry, wasn't quick enough, this offers a different explanation than my assembly manual:
http://67-72chevytrucks.com/vboard/s...19&postcount=4
Larry
Old 01-22-2012, 11:04 AM   #14
LT1 Burb
LT1 Burb's Avatar
Re: Vin Number help
I have the build sheet for my longbed and the model number does decode to a fleetside on the build sheet but not the vin I guess.
Old 01-22-2012, 11:37 AM   #15
LT1 Burb
LT1 Burb's Avatar
Re: Vin Number help
Here is a pic of the vin tag on this truck I looked at, I have never seen one with the extra stamping, any ideals.
Old 01-22-2012, 12:06 PM   #16
yelmer
Re: Vin Number help
it looks like the tag was taken off then stamped the factory rivets are gone . what is the original color is it a navy /airforce colors
Old 01-22-2012, 12:13 PM   #17
yelmer
Re: Vin Number help
the truck was built feb of 66 is the c date code for march 66 would be the delv. date and the 177 the bid contract? 144 is strange . is it a short wheel base?
Old 01-22-2012, 01:03 PM   #18
LT1 Burb
LT1 Burb's Avatar
Re: Vin Number help
Is it a SWB setpside, paint, anyones guess.
Old 01-22-2012, 07:32 PM   #19
yelmer
Re: Vin Number help
look at the kick panel on the drivers side the tag if it is still there? will have the paint code and other options mike
Old 01-22-2012, 09:50 PM   #20
irishmil
Re: Vin Number help
On the one I am looking at, it has the tag on the kick panel...is there a website that tells me what the original color was?
Old 01-22-2012, 10:54 PM   #21
yelmer
Re: Vin Number help
if you have the number i can tell you the color mike
Old 01-25-2012, 08:34 AM   #22
yelmer
Re: Vin Number help
check out tthe threaad on the dd number there is a vin similair to yours mike
Old 01-25-2012, 10:03 AM   #23
LT1 Burb
LT1 Burb's Avatar
Re: Vin Number help
I passed on it after offering him 250, 250 was too much IMO, thanks anyways. I did read up on the DD though and date code makes sense.
Thread Tools
Display Modes
