Old 01-20-2012, 10:14 PM   #1
barnold
barnold's Avatar
Accuair question
Does anyone know if you can lengthen the harness between the valve block and the ecu?
barnold is offline   Reply With Quote
Old 01-20-2012, 10:51 PM   #2
jmedero
jmedero's Avatar
Re: Accuair question
I made my harness and plug to use an AVS switch box. It took some leg work to get the right plugs and wire leads but it wa worth it. I you check out my build thread you can see what I did. This way you can make a plug in extention instead of cutting your wires.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-21-2012, 04:14 AM   #3
andrewmp6
Call them and ask if they sell something like that.
andrewmp6 is offline   Reply With Quote
Old 01-21-2012, 09:42 AM   #4
jmedero
jmedero's Avatar
I called them when I wanted to make my plug. Rio said they could not sell the plugs or harness separate.
Old 01-21-2012, 12:47 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
You sure can. How much longer does it need to be?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-21-2012, 01:03 PM   #6
jmedero
jmedero's Avatar
Old 01-21-2012, 01:05 PM   #7
jmedero
jmedero's Avatar
This is what I did.
Old 01-21-2012, 01:29 PM   #8
Hill's Rod & Custom
Hill's Rod & Custom's Avatar
You can call Accu air and ask them to make you a new connector and they probably will make a longer one. They are really customer friendly. 18772473696
www.hillsrodandcustom.com
Check out the wheel wells built to let you drive low and look like the factory....
http://67-72chevytrucks.com/vboard/s...d.php?t=465046
You can purchase them here...
http://www.hillsrodandcustom.com/?page_id=19
Vendor for:
AccuAir
California Performance Transmission - Art Carr
Porterbuilt
Hill's Rod & Custom is offline   Reply With Quote
Old 01-21-2012, 02:21 PM   #9
barnold
barnold's Avatar
Thanks for all the replys. I was see what my options were. I am trying to hide everything under my blazer but am running out of room quickly
Old 01-21-2012, 02:24 PM   #10
jmedero
jmedero's Avatar
That is what I tried to do at first was call them. It would be cool if they had this option for people to purchase.
Thread Tools
Display Modes
