Custom home made grills?
Lets see some pictures of your guys home made grills. I like the originals but sure am interested in the home made stuff, thanks
Re: Custom home made grills?
...the only thing custom about mine is I'm going to bolt a bowtie in place of where the letters GMC were on my GMC grill
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
Senior Enthusiast
Here are a couple of shots of a modified grille I ran on mine a number of years ago, first with clear parking lenses and later with amber. The center bar below the main GMC grille started life as an accessory grille guard from a 1950 Plymouth. I liked the concept but thought it would have looked better with a 1951-52 Oldsmobile grille bar (which I never found):
Just here to tinker
![]() Join Date: Jun 2008
I saw this truck in a parking lot last year and even though I am not a fan of square headlights on our trucks, I thought it was very well done.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Senior Enthusiast
I just modified my stock one a little did a write up how i did it in my build thread:
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
very nice, anymore?
Couple I have archieved
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
"Where were you in '62?"
![]() Join Date: Jul 2004
Alot of pics here:
(( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas )) http://67-72chevytrucks.com/vboard/s...d.php?t=402277
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I was wondering what a gmc grill would look like with the center portion from a 64-66 chevy grill.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#12 | |
![]() Quote:
Can you tell me more about the bumper overrider bar. I'm thinking about doing this. Is this on the bumper guards? Do you still have this? ![]() ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 06-10-2012 at 08:36 AM. |
#13 |
#14 |
Never Ending Projects
This was on a '65 I got from a friend. It was done back in the 80's.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#15 |
more of a modification but still holding together after 8 years
#16 | |
Senior Enthusiast
EDIT: I finally found a picture of a 1950 Plymouth with the guard in place: ![]() ![]() ![]() ![]() Typical to all these things the plating was terrible so I had it sandblasted and powder coated. From the front it looked reasonably cool, but from above it was just too rounded and didn’t fit well with the stock GMC grille. To mount the bar I drilled out the hanging bracket from the GMC grill and removed the support bar holding the letters. The lower powder coated support in the photo below with the chrome letters is the one off my original grille: ![]() I then fabricated triangular plates out of ¼” steel and bolted them to the radiator support with heavy wall steel spacers in back, to correctly set the spacing in correlation to the grille. ![]() When it came time to switch back to the GMC letters, I modified another letter support by removing the vertical arms that originally attached to the upper main grille bar. It doesn’t show very well in the picture above, but the bar with the white letters has angle brackets on the back which bolt to the triangle plates. So currently my GMC letters attach to the triangle plates/radiator support, not the grille. What I decided would really look perfect was a 1951-1952 Oldsmobile center grille bar because it does match the GMC grille profile. I looked for a couple of years but never found one at a price I was willing to pay. Here’s a Google image of what one looks like: ![]() If you're looking for a cross bar to tie the stock bumper guards together this could be modified to work, or there may be better choices available. If you're looking for something cosmetic only a lot of 50's cars had similar setups, the 54 Chevy passenger car being one. If I missed anything let me know.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 06-14-2012 at 11:27 AM. |
#17 |
Here's this one again from a different angle.
#18 |
This is the coolest that I've seen it is a C-60 grill with the letters removed from the top and placed in the center, then chromed. Would also look cool to remoce the letters from the top and just use the bowtie in the center
#19 |
![]() Quote:
![]() Posted via Mobile Device
#20 |
Here's mine, GMC grill, 55 Buick Roadmaster center bar with C10 horn button in the center
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
#21 |
Senior Enthusiast
I like it! Great idea and I've never seen it done before.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#22 |
Using the horn button is a neat idea.
#23 |
More here:
(( 1960-1966 Chevy/GMC Pickup Truck Restoration/Modification/Customization Ideas http://67-72chevytrucks.com/vboard/s...=402277&page=5 Posted via Mobile Device Posted via Mobile Device
Thread Tools | |
Display Modes | |
