Old 01-24-2012, 02:58 PM   #1
SHORTDOG99
Heater hose question
Do you have to use the OEM "cloth" style heater vent hose or can you use the same diameter aluminum heater hose from like Hope Depot? Is there any heat issue behind the dash i can run into using the aluminum hosing? or are both styles basically the same?
SHORTDOG99 is offline   Reply With Quote
Old 01-24-2012, 04:08 PM   #2
SHORTDOG99
Re: Heater hose question
I was reading my post and just to make it clear...I am referring to the heater duct hoses that run to the vents...NOT the rubber heater hoses that are in the motor compartment. I was sure if i was explaining it clearly.
Old 01-24-2012, 04:36 PM   #3
oldcouple
oldcouple's Avatar
You mean this stuff? http://www.summitracing.com/parts/DAC-80170
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 01-24-2012, 04:44 PM   #4
SHORTDOG99
Well yeah, that hose but i can get original style duct hose with the GM stamp on it for that price, i was just wondering if regular ol' duct hose from the hardware store that i can get for like $7. would work or does it have to be some kind of automotive grade hose?.....duct hose is duct hose....right?
Old 01-24-2012, 04:51 PM   #5
OrrieG
OrrieG's Avatar
Many moons ago I used the stuff from the hardware store on my VW cooler fan to head shroud metal to avoid the high $factory stuff. I'm pretty sure it was much hotter than a heater gets. Stuff from the big box stores is probably rated for dryer vent temps, which in a gas dryer can get pretty high.
OrrieG is offline   Reply With Quote
Old 01-24-2012, 06:18 PM   #6
SHORTDOG99
So i should be okay then..right?
Old 01-24-2012, 06:36 PM   #7
mknittle
mknittle's Avatar
I don't see why it wouldn't work. the problem is there are more sizes of automotive heater duct hose than there dryer vent hose. so you may not be able to get the size you need.
I think what orrie is saying is that old Volkswagen's used heat from the exhaust tubes, sort of a tube in a tube so if the dryer vent hose worked in that heat it should work for the truck heater that is not near as hot
Let us know what you find out
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 01-24-2012, 06:53 PM   #8
SHORTDOG99
Right on! Thanks, now to find the right size.
Old 01-25-2012, 09:25 AM   #9
54 jimmy
54 jimmy's Avatar
for $10 at the auto store i bought that air cleaner pre heater hose. it is silver foil type hose worked great had to put a sleeve in the middle to connect two piceces of it but it was cheap and should hold up to the heat.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 01-25-2012, 12:59 PM   #10
mr48chev
mr48chev's Avatar
Most auto parts stores have or can get the paper type defroster hose in various lengths.
If there is a Napa or Carquest around check with them for it.
here is a link to some at Napa http://www.napaonline.com/Catalog/Re...&Dk=1&Dp=3&N=0
Old 01-25-2012, 01:18 PM   #11
mknittle
mknittle's Avatar
LOL, I am familiar with that web site. Our local Napa store is so inept If I don't have a part number they cant find anything, and most of the time with a number they still cant find it!
Mark
My GMC build.
Thread Tools
Display Modes
