Old 01-24-2012, 09:05 PM   #1
Belairbob
C Notch and centering wheels in the fender question
Hey, I'm thinking about a mild C-notch but I have read somewhere on here about moving the trailing arm crossmember 1" toward the front so the wheel will end up centered in its opening when lowered. I would lower aprx. 6" in the rear. What do ya'll think? Would the mild C notch our vendors sell allow me to move the rear up 1" without problems?
Thanks!
Bob
Belairbob is offline   Reply With Quote
Old 01-24-2012, 09:36 PM   #2
SCOTI
SCOTI's Avatar
Re: C Notch and centering wheels in the fender question
Thanks!
Bob
Most trucks need the rear moved back to re-center the axle in the wheel opening. What year truck & type of bed?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-24-2012, 10:13 PM   #3
Belairbob
It's a 68 short bed.
Old 01-24-2012, 10:19 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
SCOTI is correct.
Normally it needs to move rearward.
Do you have any pics of your truck?
Keith
Convert to disc brakes.
Old 01-24-2012, 10:49 PM   #5
theastronaut
theastronaut's Avatar
The bolt in C notch won't work if you move the axle since its shaped to fit the frame rail directly over the stock axle location. The bolt in notch is deep enough to let the third member hit the bed floor at full drop; if youre just dropping it six inches you might be better off making you own notch from heavy wall tubing so you can position it to match your axle location.
theastronaut is offline   Reply With Quote
Old 01-24-2012, 11:16 PM   #6
Belairbob
I do not have pictures. It's in pieces at this time.
I'm cleaning up the frame now and was considering the C notch.
So I should consider moving the axle back an inch
and if I do will the "mild" C notches available be in the right place?
Thanks!
Bob
Old 01-24-2012, 11:19 PM   #7
Belairbob
OOPS, I was working on a reply and I see you have answered the question!
Thanks to all that have chimed in to help!
bob
Old 01-24-2012, 11:45 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
All the rear suspension kits we build are designed to center the wheel in the wheel well opening... and our notches are centered as well. Not all aftermarket notches are. There is some variations between wheel well opening center line on the fleetside vs step side beds. If you have any more questions, feel free to shoot me a PM with your number and I can contact you to discuss.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Thread Tools
Display Modes
