01-25-2012, 05:39 PM | #1 |
83 3/4 ton, 2 lift kits, 315 big lugs.
Severe camber problem, no visible adjustments. Anyone able to advise?
01-25-2012, 07:26 PM | #2 |
Re: 83 3/4 ton, 2 lift kits, 315 big lugs.
is the camber in or out. im no alignment specialist or anything but if im not mistaken you have to shim the top a arms. unless your ball joints are worn out. it is a 2wd right?
01-26-2012, 08:39 AM | #3 |
4WD. Camber's out at the top, about 1/2 inch from plumb. Both tires severely worn on outer edge.
01-26-2012, 11:59 AM | #4 |
You need to replace the ball joints in the front axle.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-26-2012, 08:16 PM | #5 |
x2 on the ball joints. thats a solid axle front end right?
i beat tires till they scream for life while the others watch. 2010 nissan titan. wifes truck 1979 dodge magnum e58 police package. wifes baby 1987 chevy short bed. daddys play toy 2002 stratus wifes d.d 2001 dodge 2500 cummins loaded. daddys work truck |
01-26-2012, 08:20 PM | #6 |
mine sits like that too, I had an old timer tell me thats how a 4wd chevy of this era should be. Idk I dont feel any play in the ball joints.
01-26-2012, 11:48 PM | #7 |
They also make shims for the spindles that come in degree increments
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
01-27-2012, 09:04 AM | #8 |
The camber is not supposed to be out from factory. That old timer is wrong. I have never had to do it on any of my trucks,but as mentioned there are shims for between the spindle and knuckle to correct camber. Naturally,the first thing to do is be sure you have healthy bearings and ball joints. I have only ever heard of camber being off with the top tilted in and wearing the inside of the tire. I always figured those trucks had a tweaked axle from coming down hard on it. I can't imagine anything that would tweak an axle in the opposite way.
Is you truck lifted? Maybe the axle is rolled forward to compensate for drive shaft angle. When that is done it's also necessary to clock the "C"s (axle ends where ball joints are) back to vertical for proper steering geometry. This will cause too much toe-in and wear the outer tread.
01-27-2012, 08:03 PM | #9 |
my truck is lifted and im going to be replacing front springs to match my new rears I just put in to fix the damage from an accident. The new front springs do have shims on them but Im thinking about removing them. Id rather be able to steer and have a little vibration at highway speeds. I havent looked to see if there are shims on the springs under the truck now, I'll have a look tomorrow.
01-27-2012, 08:14 PM | #10 |
6.0 powered square
have the tires been wearing uneven since the wreak
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
01-27-2012, 08:40 PM | #11 |
No, this was long before that. I was hit hard in the rear, broke the axle tube out of the pumpkin and the leaf spring on that side in 3 places. I built a new rear end for it this week and I replaced the old springs and 4"blocks in the rear with 6" springs. Next week I'll be doing the front springs to match. It had some ancient rancho lift springs and blocks so I figured it was a good excuse to upgrade.
Thread Tools | |
Display Modes | |
