Old 01-25-2012, 09:43 PM   #1
Tuck
ls engine in a 56
who has done it and were did you put the computer??
need pictures.
Tuck is offline   Reply With Quote
Old 01-26-2012, 08:03 PM   #2
Fredstruckparts.com
Fredstruckparts.com's Avatar
Re: ls engine in a 56
When we do modern motors in old cars or trucks we like to put the computer somewhere on the passanger side. Either in a kick panel, under the dash or we have even put one under the seat. Although we havent done a 56 yet ill try and find some pictures of the other cars.
Fredstruckparts.com is offline   Reply With Quote
Old 01-26-2012, 08:56 PM   #3
Lextech
Lextech's Avatar
I don't have any pics, but I like them under the seat.
Jeff
Lextech is offline   Reply With Quote
Old 01-26-2012, 09:30 PM   #4
1956chevtruck
1956chevtruck's Avatar
I smoothed over the dash where the radio goes and I put my computer in behind there. That way it's out of the weather and it's not an eyesore in the engine compartment. I have a 95LT1 in my truck.
Byron
1956chevtruck is offline   Reply With Quote
Old 01-26-2012, 09:39 PM   #5
Tuck
I need to send the factory computer off to remove the wires I dont need. since i removed the behind the seat tank I may put it there. i did here that the 2 inch bundle of wire gets preaty small. how small? i dont want a snake under my carpet.
some info.
doing a rat rod with 4 wheel disc twin turbo 4.8 with custom interior. to old to ride on springs. will have air , pw, rack pinion, nav, rear camera, start button. have the seat that was done in distrested green leather with horse blanket inserts. have 3 inch wider rear fenders and a mini tub started.
Old 01-26-2012, 11:11 PM   #6
OKGMC4
OKGMC4's Avatar
I ran my harness through the floor on the passenger side. Had to use a Mustang EECIV oval grommet to get the plugs in. Will probably velcro it to the carpet when I get it in. Even when done the bundle of wire is about 1 inch thick. I'm using an aftermarket harness but after I saw all the good info at LT1swap.com on how to do it yourself I might just attempt it myself next time and save $500.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Thread Tools
Display Modes
