Old 01-28-2012, 05:37 PM   #1
Dano69c10
Dano69c10's Avatar
Drop in back corrects camber?
I had negative camber on the front end my '70 C10, when I dropped it 3 more inches in the rear it seems to have corrected the negative camber. Is this possible? I'm gonna drop it a couple of more inches in the front so I'm sure that I'll end up with negative camber again, but I thought this was strange.
Thanx
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 01-28-2012, 08:43 PM   #2
kpeztruck
kpeztruck's Avatar
Re: Drop in back corrects camber?
Negative camber or caster? Caster will change more positive when the rear is dropped or front raised. Camber should not have changed. If so, how far negative was it? Noting of course when you raise or lower the front, you change the goemetry if done with springs, due to camber swing through wheel travel. The rear height change should only change caster. Paul
kpeztruck is offline   Reply With Quote
Old 01-29-2012, 12:03 AM   #3
oldspowered67C10
Most likely when you lowered the rear you changed the weight distribution enough to affect the front suspension.
oldspowered67C10 is offline   Reply With Quote
Thread Tools
Display Modes
