Old 01-28-2012, 11:40 PM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Clutch Pedal Bushings, Where to Buy?
I have been searching and really haven't found a thread that referred to where to buy the clutch pedal bushings. I have some slop in the pedal and want to replace these. This is for a '65 C10, if it matters.
Anyone know where to buy them from?
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-28-2012, 11:51 PM   #2
pope
pope's Avatar
Re: Clutch Pedal Bushings, Where to Buy?
are you talking about the plastic bushings?
http://www.classicparts.com/1960-72-...ctinfo/71-745/
Where the hell did my coffee cup go?!!
pope is offline   Reply With Quote
Old 01-28-2012, 11:53 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Classicparts carries them, if these are what you are asking about:
Old 01-29-2012, 12:17 AM   #4
chevy_mike
chevy_mike's Avatar
These are for the brake pedal. They say in the info about a different part number for the clutch pedal but if you do a search for it on their site, it doesn't come up.
Has anyone actually bought the clutch ones from them?
Old 01-29-2012, 12:21 AM   #5
pope
pope's Avatar
there should be 2 used one for the clutch and one for the brake, at the bottom where the description is written they give you the p/n for the clutch pedal bushing 90-769 and for the brake 71-745
Old 01-29-2012, 12:32 AM   #6
chevy_mike
chevy_mike's Avatar
Yeah, that's what I am saying, they "list" the part number for the clutch but if you try to search that number, it doesn't come up so there is no way to order it online. Makes me wonder if they really have it.
Sure I can call them Monday but would have liked to order them online tonight.
Old 01-29-2012, 12:35 AM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
I'm not aware of any difference between the clutch and the brake bushings. I've pulled a variety of them from 60-66 trucks and all looked identical to my untrained eye. I continue to use whichever ones were in the best condition. I'd be interested to know if there actually is any variance between the two.
Old 01-29-2012, 12:38 AM   #8
chevy_mike
chevy_mike's Avatar
What I have read is the clutch has a 3/4" shaft and the brake has a 1" shaft. This is why the clutch shaft can pass through the brake shaft.
Old 01-29-2012, 12:47 AM   #9
pope
pope's Avatar
same here with using the best ones, give the guys a call and see what they have to say about the part number, it was probably an oversite. They have been pretty good to work with in the past with my questions. The ones that I used were steering shaft bushings from John Deere riding mowers, perfect fit from what I rember... but that was also 14 years ago when I put the truck together
Old 01-29-2012, 12:50 AM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
Duh! No kidding. I think I've been awake too long and need a nap! Thanks for clarifying.
Confirmed - two different pairs of bushings, item 4 and item 10
Old 01-29-2012, 12:52 AM   #11
chevy_mike
chevy_mike's Avatar
Thanks guys. Guess I'll give them a ring on Monday. I'll post up what I find out.
Old 01-29-2012, 01:01 AM   #12
pope
pope's Avatar
Sorry for the confusion! I completley forgot about the inner bushings! Please keep us posted on the result for the part number if you wouldn't mind.
Old 01-29-2012, 01:01 AM   #13
padresag
http://www.dansclassic.com/product.c...D2%26dnum%3D24
ron
padresag is offline   Reply With Quote
Old 01-29-2012, 01:08 AM   #14
chevy_mike
chevy_mike's Avatar
Originally Posted by padresag View Post
Awesome find Ron!!!! The have that one (3/4") and the brake one (1"). I'll get my order place with them.
Edit: I just ordered all 4 of them.
Old 09-18-2012, 11:57 AM   #15
billbenishek
Mike,
I just got to this point and have been searching around for the 1/2" clutch pedal bushings. I just left a message for Dan's. Did you indeed find them there?
billbenishek is offline   Reply With Quote
Old 09-18-2012, 06:00 PM   #16
chevy_mike
chevy_mike's Avatar
Originally Posted by billbenishek View Post
Mike,
Yep, I got the ones I needed from there.
Sad part.... I might be switching over to an auto and not going to need them. Oh well, still a little ways away. LOL
Old 09-18-2012, 06:25 PM   #17
billbenishek
Mike
I just spoke to the guys at Dan's, but they only showed a brake pedal bushing in their system. Do you have a part number for the clutch pedal bushing?
Old 09-19-2012, 12:03 AM   #18
chevy_mike
chevy_mike's Avatar
Actually I just dug up my invoice. Here is what's listed.
382346 Clutch Pedal Bushing
383346 Brake Pedal Bushing
Just tried to look them up. The clutch one doesn't come up anymore. I recall the brake one used to list the clutch ones as a note in the description.
Guess I'm glad I got them when I did.
Old 09-30-2012, 05:37 PM   #19
billbenishek
Just an update for anyone that might end up on this thread looking for a solution. The guys at Dan's informed me that these bushings were discontinued earlier this year. I ended up buying a couple of 3/4" ID bronze oil-impregnated flange bushing from Purvis bearing. They already fit the clutch rod nicely. I reduced the ID of the bearing till it would fit in the brake tube, but turn freely. I also thinned down the flange thickness. I don't expect that I will have to replace these.
Thread Tools
Display Modes
