Old 01-29-2012, 05:20 PM   #1
bbobb
4 inch pic's of installed lowering blocks please
I am totolly clueless as to what i am doing with this one. I bought a set of 4 inch lowering blocks from a friend and ofcoarse there are no directions. If anyone has a few angled pic's of some installed would you please share them with me. I also picked up a set of Belltech 3 inch drop sprindles for the front. Will i need any thing else for the front or rear other than and spindles the drop blocks??? Thans for any and all help
bbobb is offline   Reply With Quote
Old 01-29-2012, 07:24 PM   #2
SCOTI
SCOTI's Avatar
Re: 4 inch pic's of installed lowering blocks please
What year truck are you working on?
'Drop blocks' for 6x-72 truck arm set-ups shouldn't exceed certain limits due to scrub-line issues (they become unsafe in the event of a tire failure). 15" wheels should be 1.5" max; 17" wheels 2" max; up to 20" wheels could do 3" blocks.
6x-87 C10 leaf spring applications wouldn't be able to use a drop-block until the rear end is first flipped. Once that's done, the axle flip w/the drop block will start getting into the same scrub line safety issue as the truck arm set-ups & should be limited to about 2".
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-29-2012, 07:55 PM   #3
bbobb
69 c10. with factory springs...thanks for any help
Old 01-29-2012, 07:59 PM   #4
bbobb
Unhappy Re: 4 inch pic's of installed lowering blocks please
[QUOTE=bbobb;5153971]69 c10. with factory springs. It looks like i wasted my money on the blocks . I am running 15x10 0n the back and 15x8 on the front(Torque Thrust). Will i be ok if i install 5 inch drop springs on the rear???
Old 01-29-2012, 09:11 PM   #5
SCOTI
SCOTI's Avatar
5" dropped coil springs would work.
3 or 4" springs w/a lowering block would be better because a lowering block would not impact the shock travel vs all the drop from just the spring (the shorter the spring, the less shock travel there is w/stock mounts).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-31-2012, 01:10 AM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
2/2 cut springs 2 inch block
John
1999 Toyota Tacoma 4x4
Old 01-31-2012, 11:02 PM   #7
doubleb's69
doubleb's69's Avatar
I want your truck. It's exactly what I'm looking for to use for my next faux speed shop lettered and pinstriped cruiser. Looks good.
Bud
doubleb's69 is offline   Reply With Quote
Old 01-31-2012, 11:10 PM   #8
oldblue1968chevy
check my build its a shop truck now lol
John
Thread Tools
Display Modes
