Old 01-31-2012, 09:23 PM   #1
flashed
Removing Heater
Im planning to remove the complete heater assembly from my 72 truck to install aftermarket A/C .Any tips to make it easier without damaging all the parts as they may be useful to someone else .The cab is off the frame and sitting on a dolly w/the doors off as well so access is not a problem.What all should be removed under the dash ?
flashed is offline   Reply With Quote
Old 01-31-2012, 09:48 PM   #2
rkn463
rkn463's Avatar
Re: Removing Heater
If it was heater only then it is pretty simple (at least it was on my 68)
Disconnect the cable that runs through the firewall to the air door in the underhood box - there is a plastic cover on the inside that you can pop off for access, the clip holding the cable on can be twisted with needle nosed pliers and broken in half without damaging the stud that it is pressed on to. Take the two screws out that hold the controls to the dash (from the bottom) and then unbolt the inner box from the firewall. There are a bunch of 5/16 head sheet metal screws on the inside and then two studs go through the firewall that have nuts on the under hood side that you have to remove. There are also two electrical plugs (easy to find). You may or may not have to disassemble some of the duct pieces to work it all out but it will be self-explanatory when you get in there and see it. The biggest problem I had was seperating the box from the firewall on the inside as the gasket had it stuck. I pulled mine to clean out rats nests and repaint and have not pulled the under hood box yet. I have done it in the past to replace a heater core and once again, just a matter of screws and seperate the gasket from the firewall. (Disclaimer, that was 5 or 6 years ago) I think if the truck was assembled the fender well has to come out too but you wont have that problem.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 01-31-2012, 11:05 PM   #3
Baggerjohn
Baggerjohn's Avatar
Re: Removing Heater
Please let me know what you want for the heater set up. Mine was stripped by the previous owner. Thanks
"Arrive, Raise Hell, Create Confusion, Leave".
Baggerjohn is offline   Reply With Quote
Old 02-01-2012, 08:57 AM   #4
flashed
Re: Removing Heater
Thanks for the info and Baggerjohn ,let me see if it comes out in good condition and I will let you know. Im not sure how soon I can start the removal process but I will let you know.
Thread Tools
Display Modes
