Old 02-01-2012, 05:50 PM   #1
RaTcheTmasTer
Automania
RaTcheTmasTer's Avatar
69 Big Block power steering system Questions!!
So I bought system off of a 69. It is different than the 72 systems I have.
The mounting bracket on the front is shorter and the back brackets mount under the motor mount.
Is this correct?
Also ,the reservoir mounts to the fender well on a bulging section and not up by the windshield washer bottle.
What are the differences on these 68-72 systems?
Mel? An expert on this stuff for sure!!
RaTcheTmasTer is offline   Reply With Quote
Old 02-01-2012, 09:43 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 69 Big Block power steering system Questions!!
I didn't know there were any differences in these years. 68-69 sometimes had a can extension for the reservoir. Maybe a tall deck setup is different?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-02-2012, 12:21 AM   #3
RaTcheTmasTer
Automania
Ya, I hadn't seen this style before. It was in a 69 pick up (I think half ton) and I checked the trim tag in the glove box and it listed the 396 engine. It has a small block in it but had the BB towers, BB motor mounts, big block fan shroud and this power steering system on it.
here are some pics.
Pick shows two of the rear brackets but only one was on it. The other bracket was in the bed of a truck sitting next to it.
Old 02-02-2012, 01:51 PM   #4
RaTcheTmasTer
Automania
ttt
Anybody have some knowledge on these systems??
Old 02-02-2012, 03:00 PM   #5
sameyrasmea72
sameyrasmea72's Avatar
Those brackets don't look correct to me. I know in 1968 like this truck, the resivoir was mounted on an arm (red arrow) but the other two bracket are just like all other 68-72 brackets (green arrows)
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 02-02-2012, 03:10 PM   #6
no moa
no moa's Avatar
My 69 396 has a long Brackett on the PS pump, and it was mounted directly to the fender like my 72.
Maybe someone used a small block Brackett for the BB pump?
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-02-2012, 03:59 PM   #7
custom1970
Member
custom1970's Avatar
my 1970 has the reservoir mounted directly to the fender, right next to and front of the washer reservoir. let me if you want pics
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 02-02-2012, 04:07 PM   #8
RaTcheTmasTer
Automania
thanks for the info guys.
I guess I need to get my 72 system and compare the two front brackets and see if they will interchange.
The back bracket mounts under the motor mount under it next to the engine. I will have to clean them and see if there are any #s on them.
The mount of the reservoir makes sense to me. Maybe they ran out of brackets and improvised. Or maybe the owner changed the location. I will take pics of the truck Saturday when I go back out to the yard.
I have never seen the back bracket like this before. I don't think it is small block.
Need more input and more examples.
Old 02-02-2012, 04:16 PM   #9
custom1970
Member
custom1970's Avatar
Pic of back bracket installed, hope it helps...
Old 02-03-2012, 12:00 AM   #10
RaTcheTmasTer
Automania
Nice pic Custom. Thanks.
So any thoughts here? Maybe they are some kind so small block brackets?
I have searched and can find no match for the one for the back that goes under the motor mount. I did find a pic of a 68 nova that had a similar one but not the same.
Old 02-03-2012, 12:18 AM   #11
Livrat
Member #1049
Livrat's Avatar
The pump, hoses and reservoir are correct big block, the mounting bracket on the pump and your two loose adjuster brackets are 67/68 small block.
The first pic is of a 67/68 set and the second picture is the correct Big block set..
Livrat is offline   Reply With Quote
Old 02-03-2012, 12:52 AM   #12
RaTcheTmasTer
Automania
Livrat, you have solved my mystery!! Thanks!
I thought they must be some kind of small block but for some reason I could not find any pictures for the small block setup. Is the rear small block bracket exclusive to the small block truck?
Thanks again to all who help with this!
Old 02-03-2012, 12:59 AM   #13
Livrat
Member #1049
Livrat's Avatar
I do not think that was exclusive to just the truck, I do believe the passenger cars also used the same small block PS pump and brackets
Old 02-03-2012, 03:03 AM   #14
Classic Bowties
Always on the hunt...
Originally Posted by RaTcheTmasTer View Post
Livrat, you have solved my mystery!! Thanks! I thought they must be some kind of small block but for some reason I could not find any pictures for the small block setup. Is the rear small block bracket exclusive to the small block truck? Thanks again to all who help with this!
Hi Tim, pm returned and it looks like Mark got ya figured out already. All I can add is that this type of SB ps pump brackets were for the smaller balancers found on the earlier 283, 307 & 327's, they were also used on the 68 and prior SWP cars with the 6" balancer. Mel
Classic Bowties is offline   Reply With Quote
Old 05-22-2016, 05:43 PM   #15
rod1701
rod1701's Avatar
Dumb question and rookie mistake.....
The beefy bracket for PS pump, whAt size are the bolts? Seems like the should be 3/8-16 and about 1-1-1/2" but that presentation the lower 2 holes. What is the right size? Or has some body broken it and tapped it to the next size. Any idea what goes here?
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 11-07-2018, 09:11 PM   #16
68Saddle
Do you know where I can buy one of those reservoir arms. the piece that looks silver on the picture?
thank you
Julio
68Saddle is offline   Reply With Quote
Old 11-08-2018, 04:45 PM   #17
68is4me
68is4me's Avatar
They come up from time to time on the parts board. You can do a search in there, or become a premium member and you can post a WTB add.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Thread Tools
Display Modes
