Old 02-03-2012, 11:42 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
C20 Front Spring Lift?
I'm thinking about changing out my front springs when I do my disc brake conversion. If I put in new BB springs instead of SB springs will it give me a bit of a lift? I would like to lift it a little more if possible. Any suggestions?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-04-2012, 10:17 PM   #2
derotoreut
derotoreut's Avatar
Re: C20 Front Spring Lift?
ttt
~ Dan
Old 02-04-2012, 11:57 PM   #3
FirstOwner69
FirstOwner69's Avatar
I read someplace on this forum a couple days ago that the big block front springs are the same as the optional heavy duty front springs. If that's true, and if heavy duty front springs are listed on your SPID, you wouldn't be making a change. However, if HD front springs were also available as an option on a big block truck that could be another matter. My SPID lists option "F60 HD Front Spring" on a 350 equipped C20.
FirstOwner69 is offline   Reply With Quote
Old 02-05-2012, 01:01 AM   #4
70cst
70cst's Avatar
Its my understanding the BB Springs are the same as 3/4 T springs
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-08-2012, 11:01 PM   #5
derotoreut
derotoreut's Avatar
I am wondering why some vendors list different springs for SB and BB. Performance Online asks if ordering for SB or BB.
http://www.performanceonline.com/196...-SPRINGS-PAIR/
I am wondering if other vendor's are the same. If anyone knows, about interchangeability please educate me.
~ Dan
Old 02-09-2012, 12:44 AM   #6
leddzepp
Moderator
leddzepp's Avatar
I was told to use springs from a 1 ton dually from 80-88 (I believe) and that will lift your front end and make it level with the rear. Boardmember TX Firefighter told me this a few years ago when I was looking to do the same thing with my 72 C-20.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-09-2012, 10:51 AM   #7
jrb71c20
jrb71c20's Avatar
I put some BB springs in my C20 and it didnt change anything. Bought some ranchos that were supposed to give me 2 and I got 4 instead. It beat the snot outta me down the road and was way higher than I wanted, took em off and they collect dust now. Didnt TX firefighter have set made for his? I thought I saved that one and meant to ask him
93 Sonoma 2.8/5spd
75 Malibu Classic 350/350
If it don't have round headlights and a carb, I don't trust it!
jrb71c20 is offline   Reply With Quote
Old 02-09-2012, 11:20 AM   #8
sir_talk_alot
sir_talk_alot's Avatar
thought about coil spring spacers? cheap and effective if your trying to get up higher.
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 02-09-2012, 11:29 AM   #9
Beat68CST
Beat68CST's Avatar
I'm curious also, since I'm puttin the Cummins in this pickup I know it's gonna lay over a bit with an extra 300-ish lbs up front.
Beat68CST is offline   Reply With Quote
Old 02-09-2012, 09:08 PM   #10
73CheyenneSuper20
73CheyenneSuper20's Avatar
I'm interested in this too...
My truck is the one in my signature, '71 3/4ton, with a BB 402. I'm pretty sure it needs new springs anyway, they're 41 years old. I'm going to replace them anyway, so buying just the rubber spacers won't be cheaper for me. I've been trying to figure out if the '73+ springs from a 3/4ton will work. I've been trying to get specs on both mine and those. The Autozone website lists my springs as being 12.9" uncompressed, and the '73+ as being 13.607" uncompressed. It also lists the '80+ 1 ton springs as being 13.19". I took a tape measure to the junkyard and was measuring the diameter of the springs, and they all (mine, 73+, and 1 ton) seem to about 5 1/2". 1 tons are clearly a thicker bar. At this point, I'm leaning toward putting a new set of the '73+ 3/4ton springs in and see what happens.
I have the smaller sway bar on my truck, and the rubber is shot on that also. I'm going to go with the poly bushings. As my truck sags now, I have p265/70r16s in front and p265/75r16s on the rear. The 75's squeeze in perfectly with no room to spare. I'd like to get LT285/75R16s or ideally, LT305/70R16s on the truck all the way around.
I'm rambling, but that's what I'm thinking.
Oh, from what i did see, the 1/2ton truck with a BB motor uses the same springs as the 3/4ton.
'71 C25 Camper Special, 402, TH400, Longbed, Power Loc axle, Figuring out the rest of the details....
'10 Dodge Charger SXT - DD
'91 Kasel M101A2 3/4 ton trailer (It has Chevy rims!)
73CheyenneSuper20 is offline   Reply With Quote
Old 02-10-2012, 01:22 PM   #11
derotoreut
derotoreut's Avatar
I haven't really thought about it because I am planning to do a front disc brake conversion so I was going to replace the springs while I had it apart.
~ Dan
Old 02-10-2012, 01:33 PM   #12
leddzepp
Moderator
leddzepp's Avatar
That is because your C20 already had "big block" springs. 3/4 ton, HD, and big block springs are the same thing. If you have a 3/4 ton truck, regardless of the engine size, it came with HD springs. If you have a 1/2 ton truck with a big block, it came with "big block", HD, 3/4 ton springs.
3/4 ton springs will not give you a lift over standard springs. They are the same height....it is the rate that is different.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-10-2012, 11:41 PM   #13
derotoreut
derotoreut's Avatar
I am curious to know if anyone has used different springs like leddzepp suggests to lift their front end. If so, please chime in and let me know what you used and what was the end result.
~ Dan
Old 04-19-2016, 04:50 AM   #14
benbloom
anyone know where they sell coil spacers or some kind of leveling kit? for my c20 also
benbloom is offline   Reply With Quote
Old 04-19-2016, 10:40 AM   #15
Big Kev-O
Big Kev-O's Avatar
There are some spring options in the thread below. There is even one spring listed that is taller and the spring rate is similar to stock. My C20 is stiff, I would love to level my truck out and soften the ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=556784
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Thread Tools
Display Modes
