Old 02-05-2012, 04:40 AM   #1
robg2001ls1
temp sender not reading
I have completed my 5.3 swap in my 87 silverado but one problem im still scratching my head over is why the factory temp gague wont work. Ive already tried 2 new senders and i know i have the correct green wire from the factory harness because when i ground the wire, it pegs. Wont read though. ANy suggestions? heres a link to a video from a few months ago when i first complted the swap
robg2001ls1 is offline   Reply With Quote
Old 02-05-2012, 03:58 PM   #2
jasonroman
jasonroman's Avatar
Re: temp sender not reading
bump for info for this guy
jasonroman is offline   Reply With Quote
Old 02-05-2012, 07:51 PM   #3
rayfinseats
Sender is for idiot light? Gauge broken? I have a 90 that read 230 plus and the gauge was bad.
rayfinseats is offline   Reply With Quote
Old 02-07-2012, 01:53 AM   #4
robg2001ls1
anyone?
Old 02-07-2012, 04:05 AM   #5
westie 666
westie 666's Avatar
I have the same problem
you have to use the sender from your old engin as it matches the guage
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 02-07-2012, 03:59 PM   #6
hatzie
Moderator
hatzie's Avatar
As stated above... You need a gauge sender for the 1987 CK.
Assuming you have the right sender...
Did you use Teflon tape on the sender threads?
Teflon tape can electrically insulate the sender threads and keep the body of the sender from grounding. New temp sensors only have thread sealer on the top 1/3 of the threads leaving the bottom 2/3 bare.
JIC you're interested. The temp sender is a thermistor (thermal variable resistor). You can check the resistance with a radiator thermometer and a multimeter set to 20K ohm range.
Attached is a table of the 81-90 CK RV temp gauge sender resistance vs temp.
Image is not mine. It's from this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=461255
Old 02-12-2012, 11:24 PM   #7
robg2001ls1
well i ended up trying a different sender that a friend brought me. He said it came with some parts he had bought but had no idea what it came from. It does read but not correctly. I had my cpu hooked up to hp tuners a few days back and it seemed the gague was around 30 deg off(showing cooler). Ive narrowed my problem down to the wrong sender. What is the correct part number or can someone post a pic or link of the one i should be running. The autozone one they gave me does not read(tried 2 already)
Old 02-13-2012, 02:19 AM   #8
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Is the block aluminum? If so use another or better ground.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-13-2012, 02:57 AM   #9
robg2001ls1
right now i have it tapped into the water pump
Old 02-13-2012, 12:03 PM   #10
rfmaster
rfmaster's Avatar
Need to fix broken header bolts - leaks introduce extra oxygen into exhaust stream which will effect close loop operation.
Regarding the temp sender not reading. Call your local Radio Shack ask them if they have 5K-Ohm Potentiometers, Model: 271-1714 (~$4).
There are three leads on a potentiometer. Get some test clip leads and connect center tab to green wire that goes to your gauge and one of the two outside tab terminals to a good chassis ground.
Turn ignition on and vary potentiometer shaft position - you should see your temperature gauge move. Now once you confirm that your gauge moves then correct temp sending unit can be extrapolated from potentiometer resistance values. For example - adjust potentiometer to read 210 deg F. Disconnect potentiometer from the truck test circuit and measure resistance between the two previously connected tabs. Repeat this for various temperature readings as indicted by your dash gauge. Put it in a table. In general, low temperatures correspond to high resistance sensor values while hot temperatures have low resistance values. Finding a corresponding sensor can be a PITA since there are no officially published parameter tables for temp gauge sending units. There is some DIY effort to characterize commonly used temp gauge sensors.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Thread Tools
Display Modes
