01-04-2003, 05:41 PM | #1 |
easy disc brake swap
i have just swapped my drum brakesover to disc brakes by using the front pieces off a 1988 chev pickup. all i had to do was replace my bottom a-arm from a 1/2 ton to a 3/4 ton a-arm. the top balljoint was the same one but the bottom one had to be changed to a 88 ball joint. it pops right into the 3/4 ton a-arm. it only cost me 140.00 to do it as well. then your steering linkage just has to be adjusted to fit. i hope this helps somebody.
'68 Chev C-10 '91 Western Star (workin wheels) Just an ole time truckin idiot! Jim G. |
01-04-2003, 05:58 PM | #2 |
Careful, they attack...
You have any pics? I am interested in how it looks.
01-04-2003, 06:03 PM | #3 |
i dont have any pictures yet, but will soon.
01-04-2003, 06:28 PM | #4 |
I Love This Stuff!
Damn thats a good idea, let us know how they perform and wear over time!!! My hats off to you!!
My Rides 1967 C10 In Pieces for now 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
01-05-2003, 03:26 AM | #5 |
hello JHickson6: thanks for the reply. another good thing about this swap is the parts needed for this swap are the parts from a 1988-1993 truck including ball joints which are about 1/2 the price of 1968 ball joints.
01-05-2003, 05:43 AM | #6 |
So what you used was an 88 and up spindel? with which lower balljoint, the 88 and up half, or the older 3/4 balljoint. All this utilizing the older upper control arm using the halfton balljoint?
Definetly feel the 6 lug updated adaptation may be within reach here using the newer semi-floating 14 bolt rear.!!!!!! (light 3/4ton, - 2500 series)
Member of the "Old Farts Club" |
01-05-2003, 11:54 AM | #7 |
hello Chop Top: the 88 spindel, rotor, calipers, and ball joints were used in the swap. but you need a 3/4 ton 68 a-arm instead of the 1/2 ton one. the bottom 88 balljoint fits into the 68 a-arm, and the top 88 ball joint fits on the 68 a-arm. the top 88 ball joint you half to grind the rivets off of the 88 a-arm and then bolt it to the 68 a-arm. hope this clears it up. thanks!!!
01-05-2003, 01:16 PM | #8 |
can you post some pics love to see. did toy have to change your lines or power booster just wanting to know. love to do it if i can do it for cheep. the 900.00 kits are not for me
thanks Darren |
01-05-2003, 01:36 PM | #9 |
67-72 Addict!
dream 69, Welcome to the board from Maryland. This sounds very interesting!. We would love to see some pics when you can. I don't drive my truck enough to justify the $700 kits either but would go for half of that if it's as simple as you say. I'm assuming you used the 88' 4x4 brakes to retain 6 lugs?. Did you use the newer style Master Cylinder and booster? Thanks.....Jim
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 01-05-2003 at 02:17 PM. |
01-05-2003, 02:16 PM | #10 |
I wonder if the 76 3/4 ton lower arm with do? Thats whats under mine now. I would love to try this setup. That would give me more reason to re-install the older style upper arm with new bushings. Is this going to change my track width any??
01-05-2003, 02:20 PM | #11 |
Hello chop top,
I believe the '76 3/4 ton lower arm is exactly the same but has a higher rubber snubber on it. So in my opinion it shouldn't change the track width any. dream68
01-05-2003, 02:46 PM | #12 |
Fabricate till you "puke"
Dream 68, thats an interesting swap! how did the tierods work out with the 88 spindles?(or better put...which ones did you use?)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-05-2003, 05:56 PM | #13 |
Resident Young Old Dude !
Dream68, Welcome aboard !!!!
That's the way I tried to do it, but didn't know the 3/4 ton was different. A friend gave me 2-1/2" drop spindles off of a newer truck, I bought everything to do the switch, But it came to a stop when I found out the lower ball joints were different, No one around here knew how to get around it. I went to Tuckers in Las Vegas and bought the complete disc brake,spindle kit from them. Wish I would have known this then. would have saved me about $600.00. That's nice about a board such as this, With so many people doing this stuff we learn most of the time the easy way instead of the hard way..... |
01-05-2003, 06:39 PM | #14 |
hello 70C10: i am going to use the master cylinder and booster off a 70 1/2 ton. will work just fine.
01-05-2003, 07:44 PM | #15 |
Drum master on Calipers?
I don't think that is going to provide you with enough fluid volume for the calipers.
01-05-2003, 07:48 PM | #16 |
2nd that chop top......the calipers will hang also with the residual valve on the drum master......
01-05-2003, 07:57 PM | #17 |
ok guys, which year master do you suggest?
01-05-2003, 08:24 PM | #18 |
71-72 I think would be the best, unless someone else has found another one that will bolt on our trucks.
01-05-2003, 08:29 PM | #19 |
dream 68, i have always been a beleiver in peel the parts off the same truck if you can. My 69 longhorn has ALL the pcs off a 75 C10(master, lines,hoses,prop valve,calipers,reardiff/brakes......yep, its a 1/2 ton ride now! I couldnt say for sure on your combo, but i dont like to mix em. Generally, the pcs that were designed together tend to work best together. Good luck.....crazyL
01-06-2003, 08:05 PM | #20 |
Crazy Longhorn: sorry so late getting back. i used the steering linkage from the 68. the tie rod ends fit the 88 spindle .
01-06-2003, 08:05 PM | #21 |
01-06-2003, 08:21 PM | #22 |
Thats cool, its sounds like it will get around all the center link/tierod issues that are involved with using the 71-72,or 73-87 pcs on the older trucks!
01-06-2003, 11:36 PM | #23 |
THE QUICKER FIXERUPER
Dream68 youve got me thinking. Chevy made 6lug 2wd 3/4ton truck 88 up, so would the balljoints and evreything still work, I am wondering if the 6lug spindle is the same as the fivelug so i wouldent have to change the rearend.
01-07-2003, 01:19 AM | #24 |
GMC JUNKIE TOO: my 68 chev was a 6 lug before the swap , and is after the swap. all parts work as i have stated before.....
01-07-2003, 01:20 AM | #25 |
the 6 lug is the same...
Thread Tools | |
Display Modes | |
