02-18-2012, 12:01 AM | #1 |
Assembly Date code Question
Hello all! My first thread!
I have a 1972 Chevy K-10 4x4 and I am looking for a correct engine block. I need to find the date of assembly of the truck in order to get a date correct block. Where do I locate the assembly date of the truck? The glove box door and tag on the drivers door opening are no help. Thanks! By the way, I am looking for a 350 4bl, manual trans. block........ |
02-18-2012, 02:54 AM | #2 |
Re: Assembly Date code Question
i think the last six numbers in your vin number should have somthing to do with it
02-18-2012, 10:51 AM | #3 |
If you post the following part of your VIN, I think we can get within one month for you. CKE142S167XXX. I would need the part beginning with the plant code (S in this example) followed by at least the next three characters (all numbers). Some of us have collected a significant amount of data on VIN/Build Dates. You can also check the dates on your seat belts.
02-18-2012, 10:57 AM | #4 |
Ok, Sorry. The vin is: CKE142F152198
02-18-2012, 12:56 PM | #5 |
Vintage 4x4s
Also check your drivers door in the latch area. There might be an assembly date sticker there. I'm not talking about the Vin tag thats riveted on. What I'm referring to is a blue sticker applied to the door itself. Once you know the month you can lookup the date/model engine codes on the web.
there is also a date tag on the transfer case.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-18-2012, 05:07 PM | #6 |
Good to know and its great to be helpful and learn somthing
02-19-2012, 01:47 AM | #7 | |
02-19-2012, 09:16 AM | #8 |
Did you get the date from the upper right corner of the door sticker ? Below is one from a 72 Longhorn with the date of 2/72 ( February ) . . . . |
02-19-2012, 10:17 AM | #9 |
02-19-2012, 10:21 AM | #10 |
Vintage 4x4s
Yeah probably 2/72. What is the full number stamped on the pass side top of deck (in front of head) on the D112 block?
02-19-2012, 10:24 AM | #11 |
It is "V0412TRK", (K20, 4 bolt, 175hp)....Closest I can get. I will probably deck it anyway for peace of mind (so everything is straight)
02-19-2012, 10:32 AM | #12 |
What is a longhorn?
02-19-2012, 10:33 AM | #13 |
The Niner
So that's Flint, April 12th.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
02-19-2012, 11:24 AM | #14 |
02-19-2012, 11:26 AM | #15 |
It's an eight foot bed with an extra six inches added in the front ( as seen in the picture below by the vertical line in front of the tool box )
Larger slide-in campers could be used. . . . . |
Thread Tools | |
Display Modes | |
