Old 02-19-2012, 01:26 PM   #1
GMCMG
GMCMG's Avatar
Unhappy What has my 6.2 oil pump beeen chewing on???
Hey, guys. I'm doing a '66 Suburban build with a '82 6.2 Diesel intended to go under the hood. The guy I got this off of cleaned it and painted it (black - why black?) and put some new peripherals here and there before going to a different project. He said the rear main seal was weeping and I should fix it.
I got it on the stand, flipped it, pulled the pan and went towards the rear main. Since I was in the pan, I thought I'd check the oil pump. I pulled it apart, and the plate looks almost new. I almost just threw it back together and called it good, but since it was apart it was a great time to clean everything. Might as well get as much gunk as possible. When I pulled the gears, this is what I saw; what has my oil pump been chewing on? Looks like maybe wire or something? There is damage at contact points on both gears in several places. Should I be worried about something?
GMCMG
1964 GMC 1/2 ton LWB project
- 1982 GMC 6.2 diesel engine/suspension donor
- 1966 Chevy 3/4 ton frame/doors/fenders donor
- tons of parts - cause you can't build a truck without 4 of everything!
2001 3/4HD Duramax Diesel extended cab lwb4x4
1984 Chevy C30 6.2 diesel lift truck (project)
1962 GMC w/5 lugs, 350/350 auto (was for parts, but couldn't bring myself to do it!)
glascock.m@hotmail.com
GMCMG is offline   Reply With Quote
Old 02-19-2012, 02:57 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: What has my 6.2 oil pump beeen chewing on???
Ouch! Not sure what could have gone through there but those should probably be replaced. Hopefully the rest of the internals look a lot better than those. I would be motivated to pull a main cap and check out a bearing while I was in there.
Old 02-19-2012, 03:19 PM   #3
GMCMG
GMCMG's Avatar
Pulled a main, and it looks good. Still trying to figure out where the mystery metal came from. It would have had to be light enough to get picked up, and then how did it get through the screen? So far nothing obvious wrong with the engine. Even the rest of the oil pump shows no damage. Getting ready to pull the other main blocks I guess...
Oh, and any idea where to get just the gears? Hate to pay $65 for a whole new pump if I could get just the gears somewhere for cheap.
GMCMG
Old 02-19-2012, 03:21 PM   #4
hatzie
Moderator
hatzie's Avatar
On a nicer note. The oil filter is the next stop so the junk prolly didn't go any further.
I agree with pulling a few bearing caps while it's upside down.
Old 02-19-2012, 03:31 PM   #5
GMCMG
GMCMG's Avatar
Re: What has my 6.2 oil pump been chewing on???
Originally Posted by hatzie View Post
On a nicer note. The oil filter is the next stop so the junk prolly didn't go any further...
Yes, I was praising the awesomeness of a $5 oil filter in comparison to the damage it likely saved to the engine. It caught the culprit piece AND the few chunks of gear tooth!
GMCMG
Thread Tools
Display Modes
