Old 02-20-2012, 10:57 PM   #1
jayboe
59 dually conversion
I just got a good deal on a set of 16 inch wheels from an 87 1 ton Chev dually.. What kind of problems can I expect when trying to convert my 59 1 ton single rear to accept these wheels? I figured i would need to change to longer studs, but not sure about what else... Thanks in advance!
jayboe is offline   Reply With Quote
Old 02-20-2012, 11:06 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 59 dually conversion
Only other problem I can think of is the inside tire rubbing the leaf spring. The spring pads are 60.5" on dually trucks.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-21-2012, 01:48 AM   #3
meter swinger
meter swinger's Avatar
^yep^. What would be easiest would be to get ahold of a cab&chassis (commercial truck) dual rear end from 73-91. Just a touch narrower but the inners would clear.
meter swinger is offline   Reply With Quote
Old 02-21-2012, 09:30 AM   #4
1959 Apache 3600
1959 Apache 3600's Avatar
My plan WAS to go dually on my '59 3/4 ton. I had a dually rear end located that I was going to put in.
1959 Apache 3600 is offline   Reply With Quote
Old 02-21-2012, 09:59 AM   #5
jayboe
I may just leave mine alone haha...
Old 02-21-2012, 12:31 PM   #6
meter swinger
Judging by the flatbed in your pic i think it would look awesome with a dual rear.
Cleaned up with nice wood and paint.
Old 02-21-2012, 05:41 PM   #7
jfnar
You'll have to have different front hubs to run the dually wheels on front. There are lots of folks that are interested in switching from duals to singles so you might find someone willing to swap some parts. Check out the Stovebolt page (www.stovebolt.com) and put an ad there and you'll probably find somebody interested.
jfnar is offline   Reply With Quote
Old 02-25-2012, 10:38 AM   #8
63 & 64 Bowties
and a few others
plus, the newer dually wheels won't clear your brake drums. You'd have to run 2" spacers which would make it even wider.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-25-2012, 10:42 PM   #9
G&R's57GMC
G&R's57GMC's Avatar
Here's another way .... 1 ton dually chassis
G&R's57GMC is offline   Reply With Quote
Old 02-28-2012, 08:49 PM   #10
BigJackDaddy
BigJackDaddy's Avatar
The wheel hub center is longer on a real dually... long enough to support both wheels at their centers. Your lug nuts simply hold the wheels against drums/rotors. It's the wheel center that supports the weight of the vehicle.
Even though there are kits out there, they all come with the appropriate disclaimers. It's a bad idea to expect only the wheel studs to hold all that weight.
ColoradoMelons.com
BigJackDaddy is offline   Reply With Quote
Old 02-29-2012, 10:26 AM   #11
jfnar
Here's a '57 3800 dually rear hub: Name:  57hub.jpg
Here's a rear hub from a '70 single wheel C30: Name:  70hub.jpg
The '70 has shorter bolts because it's for a single wheel and a 1" spacer plate. Otherwise they're identical. I'm not sure but I believe that the spacer plate may be there so that 16" dual wheels will clear the drum. Or it could be just to increase the track width by 2" because the '70 trucks were slightly wider than '57's.
Old 02-29-2012, 11:59 AM   #12
jayboe
I guess I'll take the wheels off and take a look..
Thread Tools
Display Modes
