Old 02-20-2012, 11:29 PM   #1
Dustytrix
o2 sensors
I am still gathering parts for my 5.3 conversion. Where is the best deal I can get on o2 sensors? Or can I pull some from a junk yard you think? This is a 04 engine do they have to be from a silverado since the engine cam out of one?
Dustytrix is offline   Reply With Quote
Old 02-21-2012, 03:41 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: o2 sensors
Rockauto.com I wouldn't mess with used sensors.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-21-2012, 04:47 PM   #3
ls1nova71
ls1nova71's Avatar
Re: o2 sensors
I agree, Rockauto.com is way cheaper than the local parts stores. If I don't have to have a part right now, that's where I go.
And I would get o2 sensors that match your engine as there are different connectors, wire length and grounded versus case grounded, is better to stick with what it originally had.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-21-2012, 05:33 PM   #4
Dustytrix
Re: o2 sensors
Thanks for the info guys. I will check rockauto out.
Old 02-21-2012, 08:02 PM   #5
mooseknuckles
mooseknuckles's Avatar
Re: o2 sensors
I just looked into this myself...my harness call for a o2 sensor gm pn#25312184....havent looked into the gm price, but the ac delco afs75 is about $60...and theres a bosch one thats supposedly cheaper than the ac delco....
mooseknuckles is offline   Reply With Quote
Old 02-21-2012, 08:28 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: o2 sensors
bosch is good...
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-21-2012, 09:14 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: o2 sensors
I ordered some from A1 auto, I think off ebay, and they didn't fit my wiring, so I bought some Bosch from Advanced auto. They weren't working with my computer since the computer used to run a 4L80 trans. and was changed over to run a 4L65. So I threw in some used GM o2's and shazaam, o2 code gone. I don't understand it either. John at Speartech figured it out.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-22-2012, 02:23 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: o2 sensors
change your harness to run bosch generic 02's. Since all o2's serve the same function (give or take the addition of a heater circuit) there isn't any reason to use a vehicle specific one. I think I used #13444's and they were less than $30 each, the plugs for them aren't expensive either. Also is cheaper in the future if you need to replace them, and most parts stores have them around.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-22-2012, 10:55 AM   #9
Dustytrix
Re: o2 sensors
I didn't get the female plugs with my harness, so changing the wires won't be a problem since I have to hardwire them anyway. Thanks for the tip.
Old 02-22-2012, 06:51 PM   #10
mooseknuckles
Re: o2 sensors
.....good tip.
Old 02-22-2012, 11:56 PM   #11
nacho55
Re: o2 sensors
Like Br3w said the Bosch .. I just ordered a pair off amazon for under $30 apiece with shipping and they had the plug end I needed.
nacho55 is offline   Reply With Quote
Old 02-23-2012, 06:34 PM   #12
Dustytrix
Re: o2 sensors
Do you have the part# at amazon?
Old 02-23-2012, 07:40 PM   #13
nacho55
Re: o2 sensors
Here's the part number I ordered says its an oe fit for the pre-cat o2 sensors.
Part#13026 , they were 27.19 each and charged 4.59 to ship 2 of them,
Old 02-23-2012, 09:19 PM   #14
52 Rat
52 Rat's Avatar
Re: o2 sensors
I just ordered two new AC Delco's from Rockauto. They are $109. at the dealer and $90.00 at the parts house. Rockauto has them for $47.00 each.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 02-23-2012, 11:16 PM   #15
Dustytrix
Re: o2 sensors
I went ahead and got the Bosch 13026 from amazon, thanks for the info nacho, and everyone else. Oh yea the adapter plate for the flywheel,torque converter I ended up going with jegs they have them on sale now for 39.00.
Old 02-24-2012, 01:23 AM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: o2 sensors
what plugs are you using? The 13026 shows a 4 wire flat plug, but no OE interchange listing (at least per there website )
The 13444 uses the common square 4 wire plug from many GM 90-2000's cars
Old 02-24-2012, 09:13 PM   #17
Dustytrix
Re: o2 sensors
I couldn't find oe interchange there either, but I found it's for late 90s to 02 trucks, I think I looked it up on auto zone. But I don't have ends anyway, gonna hardwire them.
Old 02-24-2012, 11:17 PM   #18
nacho55
Re: o2 sensors
My harness had the 4 flat for the front so they should work fine for mine. The oriely's site had the same part number also
Old 02-25-2012, 02:46 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: o2 sensors
please don't, o2 sensors are a wear part, even though its a "fun car" you can and may eventually burn them out....and rewiring crap constantly is annoying.
You can usually get a set from a junkyard for a few bucks, or free if you buy something else, since most pick and pulls don't care or inventory random wiring connections off the main harness.
Old 02-25-2012, 09:52 PM   #20
Dustytrix
Re: o2 sensors
I agree I could use plugs if I can find some before the swap begins I will hard wire the plugs. But if I can,t locate any at least I have the o2 sensors ordered.
Old 02-26-2012, 01:37 PM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: o2 sensors
http://www.ebay.com/itm/LS1-OXYGEN-S...#ht_500wt_1054
Or if you want both sides of the plug
http://www.ebay.com/itm/GM-4-PIN-FLA...#ht_500wt_1054
Old 02-26-2012, 06:24 PM   #22
Dustytrix
Re: o2 sensors
Thanks BR3W now I can put them in right the 1st time.
Old 02-27-2012, 09:00 PM   #23
Dustytrix
Re: o2 sensors
Ok I got my bosch o2 sensors in today, now can anyone tell me which wire terminates to where in the 04 blu,grn connectors for my computer? The o2 sensor colors are gray, black, and 2 whites.
Old 02-28-2012, 08:12 PM   #24
Dustytrix
Re: o2 sensors
I found out how to wire these 02 sensors up. Now can anyone tell me the best place to install them. I will be using manifolds and duel exhaust. thanks
Old 02-28-2012, 11:22 PM   #25
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: o2 sensors
after the manifold, within the first 6-8" of pipe, and between the 10-2 oclock position (top) of the pipe
Thread Tools
Display Modes
