Old 02-22-2012, 12:41 PM   #1
jrobertop88
jrobertop88's Avatar
bench seats
I know you have probably have discussed this before bit I can't any info. I'm new to the site by the way, sorry. The name is Jose I'm from anaheim ca, if there's any local guys out here with projects, hit me up I got questions. Back to my question, will a 75 cheyenne bench seat fit in a 65 stepside??? Thank you
jrobertop88 is offline   Reply With Quote
Old 02-22-2012, 01:08 PM   #2
XtechX
XtechX's Avatar
Re: bench seats
Yes, I do believe it will fit. I think GM bench seats all the way through the 90's will fit without any or very little modification.
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 02-22-2012, 01:13 PM   #3
jrobertop88
Smile Re: bench seats
Thanks for the info, you replied just on time too. I'm at the junk yard pulled it and was waiting at the register window. Good lookin out thanks again
Old 02-22-2012, 01:58 PM   #4
krazy_texan
krazy_texan's Avatar
Re: bench seats
i thought you had to use the mounting brackets off of the older bench to mount the 73-87 seats in the truck because they had the side tanks that came up under the cab the floorboard sits much higher than in other chevy trucks but still it is a very easy fix either way.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-22-2012, 02:13 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Re: bench seats
Welcome to the forum. Good luck with your project.
Old 02-22-2012, 03:20 PM   #6
62 short step
62 short step's Avatar
Re: bench seats
Yes this is correct. I welded my brackets from my old 64 seat to a mid 80's seat.
Worked out good.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 02-22-2012, 06:14 PM   #7
XtechX
XtechX's Avatar
Re: bench seats
I measured my square body seat (1977 swb) and the seat will fit in nicely, Krazy Texan is correct, you will have to use to use the seat brackets off from your 65 seat, or make some brackets to make it work.The front of a 65 stock bench sits about 6 inches off the floor of the truck and the rear sits about 3 inches off the floor, just incase you don't have the original seat brackets.
Old 02-23-2012, 02:04 AM   #8
jrobertop88
Re: bench seats
Thanks to everyone, the bench worked out good did some drilling and it went in fine with the tank still in the cab, but ran into deeper sh!#. I blew the three speed tranny on it, now I got look for a tranny that fits and can handle the 350, and still be good on gas, since cali gas prices go up more than they go down. Looking to get a 700r4 for it with a floor shifter. Any other ideas?
Thread Tools
Display Modes
