Old 02-24-2012, 09:50 PM   #1
cb1965
cb1965's Avatar
how much drop is too much?
will i have an issue with 2.5 drop spindles, 3" drop springs front, 5" springs rear with 1.5" lowering blocks.
FRONT = 5.5" total drop
REAR = 6.5 total drop
anyone have this setup? any pics? suggestions. thanks
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 02-24-2012, 09:59 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: how much drop is too much?
one word yes....2.5 spindles and 1.5 drop springs front, 5 inch rear, unless you c-notch the rear.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-24-2012, 10:01 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
You wont as long as you dont hit anything! My front drop is the same and it leaves the a-arms very close to the ground. Front travel is limited for bumps.
If you are used to driving lowered trucks you will be ok; if not its going to be a learning experience. Constant scanning for objects/holes, how to gun it over speed bumps so you dont scrape, at what angle to hit sloped inclines while turning, etc.
It'll look totally cool!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-24-2012, 10:09 PM   #4
cb1965
cb1965's Avatar
my '65 is lowered 4.5 front and 4 rear. i love the way it looks and drives. for my '66 i wanter more of a slamed look but no bags.
how does your truck handle protrash?
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-25-2012, 12:10 AM   #5
baggedbigblock
How much drop is too much? When the frame eats the pavement, and then its perfect!
baggedbigblock is offline   Reply With Quote
Old 02-25-2012, 01:01 AM   #6
cb1965
cb1965's Avatar
i want her low, but that may be a little too far...
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-25-2012, 03:01 AM   #7
Sicboy
Sicboy's Avatar
Do you have any pics? That's the setup I'm thinking about.
Gary
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 02-25-2012, 11:50 AM   #8
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
and then some!!!
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 02-25-2012, 01:20 PM   #9
cb1965
cb1965's Avatar
Gary
this is the best shot i have of it now
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-25-2012, 02:10 PM   #10
Sicboy
Sicboy's Avatar
Thanks, it looks sweet! Can you get a side shot?
Old 02-25-2012, 07:46 PM   #11
cb1965
cb1965's Avatar
heres a few more. no wood in bed.
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-25-2012, 08:19 PM   #12
rudy350
Nice truck u running leaf springs ortrailing arms
rudy350 is offline   Reply With Quote
Old 02-25-2012, 08:26 PM   #13
cb1965
cb1965's Avatar
thanks. trailing arms. its a chevy with a gmc grille
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-25-2012, 08:31 PM   #14
cb1965
cb1965's Avatar
so i figured ill go ahead and drop it 5.5 in front and 6.5 in the rear and see how it goes. if worse comes to worse ill just cut my stock coils and go from there. thanks for input guys.
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-25-2012, 10:42 PM   #15
SCOTI
SCOTI's Avatar
How much is too much depends on how it's done (what parts are used). A 6" front drop using spindles & springs will have alot less ground clearance vs another one set-up w/a Dropmember or frame Z & some spindles.
With your 2.5" spindle /3" sping combo, that's prob about the max & still be daily drivable. You'll still have to be aware of road quality conditions & such but not to the point of being paraniod every time your slip behind the wheel.
The 5" spring w/1.5" block is plenty do-able. I would recommend using an air bag so you can still use the truck as a truck if desired.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-25-2012, 10:57 PM   #16
rudy350
Cool ,. Ok im confused I love the way the green Chevy looks and its stand .. What that set up ? Did u just get lower spindles,or front springs also? And the the rear how much u lowerd it? Where did u get the parts from? I know alot of questions : )
Old 02-25-2012, 11:50 PM   #17
1enick72
1enick72's Avatar
I'm interested in doing air bags in the rear on my drop because it will still be used as a truck for a while. I don't need a whole kit with compressor and all just bags, some lines and a valve at the back. What would I need and where would I get parts for this set up?
I hope I don,t d-rail this thread too much.
1enick72 is offline   Reply With Quote
Old 02-26-2012, 12:09 AM   #18
cb1965
cb1965's Avatar
the front has 2.5" drop spindles and 2" drop springs. you will need to upgrade to disk brakes if you have not already. the rear has 4" drop springs. i got the cpp spindles from summit racing, shipped to my house was cheaper than going through cpp. the springs i got from cpp. you can sometimes find drop springs and shocks on ebay.
'66 chevy lwb c10
'65 chevy lwb c20
Old 02-26-2012, 12:15 AM   #19
rudy350
Thanks for the info , and again your truck is sick....
Old 02-26-2012, 12:54 AM   #20
protrash64
protrash64's Avatar
I like it very much. Ride is good and it corners good with a big sway bar in front. I just have to be careful with road conditions. I did cut the bumpstops off the a-arms for a little more travel.
Old 02-26-2012, 01:12 AM   #21
SCOTI
SCOTI's Avatar
2x 6"/2500# bags (I like Firestones or Slam Spec's RE-6's)
2x 90° air fittings for the bags
2x schrader fittings to fill
Enough DOT air line to run from the bags to where you plan to install the schraders (<20' prob).
I would plumb the bags independently to prevent excess loading. 'Excess' meaning air pushing from one side to the other when leaning in a turn thus making 'normal' body roll more pronounced.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-26-2012, 10:43 AM   #22
ratskin
I'd say 1" is about 1" too much, but I'm an old timer...
ratskin is offline   Reply With Quote
Thread Tools
Display Modes
