Old 02-26-2012, 04:49 PM   #1
Tntruckguy
Tntruckguy's Avatar
1950 5 window project
Hi ya'll! Im gonna add pics of my project here for everyones comments and advise as I move this thing forward. Any help is appreciated. This is my first AD truck and I love it! It has a 71' Nova Clip and all original parts (so far).
Tntruckguy
Tntruckguy is offline   Reply With Quote
Old 02-26-2012, 04:54 PM   #2
Tntruckguy
Tntruckguy's Avatar
Re: 1950 5 window project
So we finally got the Chassis done and started on the Cab. We ordered floor pans and cowls from LMC Truck and started in on that. We found a 1980 Chevy SB 350 from a local junkyard with a rebuild tag on it. After repainting and a little chrome, it came out looking pretty good.
Tntruckguy
Old 02-26-2012, 05:02 PM   #3
Tntruckguy
Tntruckguy's Avatar
So after all that and floor pans almost complete, we mocked up the cab on the chassis and found out we had a clearance problem with the radiator. This 71 Nova clip( rear steer) and its mounts could not move far enough back. Looks like about 4.5 or 5 inches from Distributor to fire wall. I found a local hot rod fab shop so the truck is on its way to them this coming week. They are going to raise them up a little and move back, set the trans crossmember I bought from Brothers Truck and mount Radiator and Electric fan. I have found out also that because I lowered the truck I will have to use 14 inch 4.5 Rallys that came stock on this Nova. Just to keep all the clearance issues in check that I have created. I think once I get them on I will be happy with the look.
Tntruckguy
Old 02-26-2012, 05:04 PM   #4
Tntruckguy
Tntruckguy's Avatar
The tires in the pic above are 205 70R 14's with 4.5 centers. I had to remove the single piston calipers to get these rims on to check clearances. They will come off and get sold when I get the 14 Rallys.
Tntruckguy
Old 03-13-2012, 11:06 PM   #5
Tntruckguy
Tntruckguy's Avatar
The Truck is now at the Fabricator and as you can see by the pics, the motor needs to move back several inches.
Tntruckguy
Old 03-13-2012, 11:12 PM   #6
Tntruckguy
Tntruckguy's Avatar
With this truck sitting on a 71 Nova Clip, I thought it only fitting to find a set of orginal 71' Nova Rally Wheels. After a little bit of elbow grease I got them looking pretty sporty. I did have to find a set of two 6" Rallys so I could get the clearance that I need. 195's on the front for sure and looking at 60 series 235 or 245's on the back.
Tntruckguy
Old 03-13-2012, 11:15 PM   #7
Tntruckguy
Tntruckguy's Avatar
BTW, I used Duplicolor Silver Wheel Coating from Advance Auto. It has a little bit of flake in it and dries rather quickly. The wheels look great in the sunlight. This stuff was only about 6.50 a can and one can would do it.
Tntruckguy
Old 03-13-2012, 11:29 PM   #8
sgtusmc
sgtusmc's Avatar
Looks really good man. I like the way the engine and rims turned out. Good luck on those floor boards.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 03-13-2012, 11:29 PM   #9
av8tr33337
av8tr33337's Avatar
Looking good. I'm subscribed!!!
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 03-13-2012, 11:35 PM   #10
Tntruckguy
Tntruckguy's Avatar
Thanks Y'all! I should have more pics up this weekend! I have the new floor pans in just no pics yet. We had to mock up the cab when we noticed the motor mounts were in the wrong spot. So...once we fix that and set the Trans mount, back on the cab I go.
This is a great forum and full of lots of great info and innovation. Should have been here a long time ago!
Tntruckguy
Old 03-14-2012, 10:02 PM   #11
Root2812
Root2812's Avatar
Keep and eye on them. I used that same stuff on the aluminum wheels on my wifes car. The paint was pealing so I sanded them, etched primed them, painted them with the same wheel enamel and the matching clear. It went on and looked great just like you said but less than a year after it started to crack and look bad. I'm looking to repaint the wheels again.
Root2812 is offline   Reply With Quote
Old 03-14-2012, 10:48 PM   #12
Tntruckguy
Tntruckguy's Avatar
I did not use the clear. Do you recomend to use it? I see you (root2812) are in MN. Thats a rough winter up there....maybe in TN I might get a little longer out of the paint. This truck is also garage kept and only will be allowed out on the weekends!
Tntruckguy
Old 03-15-2012, 04:12 PM   #13
_Ogre
_Ogre's Avatar
mmmmm, yellow engine, i like it
why didn't i think of that?
shop air compressor timer
Old 03-18-2012, 11:57 AM   #14
Tntruckguy
Tntruckguy's Avatar
Well the truck is at USA Chassis in Maryville, TN. getting a upgrade on the clip and a few other items addressed. I will post pics this week. I have attached pics of what I am shooting for on my finished product. I guess this is kinda like hanging a Farrah Fawcett poster on your wall.....if your from that generation!!!
This is the link to USA Chassis's new under construction website:
http://www.usachassistn.com/#
Tntruckguy
Old 03-18-2012, 10:56 PM   #15
Tntruckguy
Tntruckguy's Avatar
Worked all night on the stock grille.whew! Now its in pieces on the garage floor. Off to the sandblaster and chrome shop.
Tntruckguy
Old 03-18-2012, 11:06 PM   #16
skymangs
skymangs's Avatar
Hey TNtruckguy, great project! Could you post some pics of the Nova clip where it attaches to the stock frame? I'm considering my options, and wanted to see how well it all lined up.
skymangs is offline   Reply With Quote
Old 03-19-2012, 08:37 AM   #17
Tntruckguy
Tntruckguy's Avatar
Cool Re: 1950 5 window project
Sure will! I will be down at the Fab shop today. I had planned to but up some pics of the clip.
Tntruckguy
Tntruckguy
Old 03-19-2012, 09:56 AM   #18
xpickup
xpickup's Avatar
Tntruckguy, Looks like a great project. Keep up the great work.
Shannon
xpickup is offline   Reply With Quote
Old 03-19-2012, 03:51 PM   #19
Tntruckguy
Tntruckguy's Avatar
Hey Skymangs! Here are the pics you asked for. Sorry the detail is not great! (bad lighting). I spend alot of time in the Northwest corner of your State. Im actually from there! I really miss it!
Tntruckguy
Old 03-19-2012, 07:39 PM   #20
skymangs
skymangs's Avatar
TnTruckguy, thanks for the pics. Looks like the frame width is pretty close, and the wheel track width looks like it is pretty good. This may be the option I go with. Is that 2x4 boxed steel used to connect the two? 1/8th wall? Do you by chance have any of your measurements still?
My son turns 14 in about 2 months, and we'll start his first truck. Ironically, he chose to build my first truck (the '47). It's been in storage for going on 20 years! Makes a father proud.
I'm PCSing to MO this fall, maybe we'll see each other at some of the same events!
Old 03-21-2012, 06:55 PM   #21
Tntruckguy
Tntruckguy's Avatar
Skyman, I checked with USA Chassis and it is 2X4 boxed steel but it is 3/16ths thick. They said this is the best to use. I will post pics of the finished product soon.
Tntruckguy
Old 03-25-2012, 06:37 PM   #22
Tntruckguy
Tntruckguy's Avatar
Looks like we got the clip work all done and gonna finish out next week by cleaning up the chassis, a little paint and then on to the motor and trans mounting. Here is the website and facebook site for USA Chassis! They are doing a great job! I will post pics this week.
https://www.facebook.com/USAChassis
Tntruckguy
Old 03-26-2012, 05:06 PM   #23
Tntruckguy
Tntruckguy's Avatar
Posting pics of the Chassis! As promised
Tntruckguy
Old 03-30-2012, 02:19 AM   #24
Tntruckguy
Tntruckguy's Avatar
Hey guys, any input on installing a power rack steering system. Make/Model, etc! I should have pics up this weekend!
Tntruckguy
Old 04-10-2012, 09:56 AM   #25
Tntruckguy
Tntruckguy's Avatar
Well the project is making some headway this week. The cab is getting its final welding. The mustang II power rack system is waiting for installation. Master and booster out of a mid eighties camaro is waiting to be installed also. Work is complete on the chassis! Motor and trans set. Custom motor mounts fabricated and installed by USA Chassis and Metalworks of Maryville, TN. A little final welding and its ready for the mock up of the front clip. I will post more pics when we get there.
Enjoy!
Tntruckguy
Thread Tools
Display Modes
