02-26-2012, 11:17 PM | #1 |
Towing with "C" Notches
Dose any one know if you can tow a trailer if your truck has "C" Notches? If you can, what would be the best one to use? I won't be towing anything everyday just if I need to trailer a car or possibly a camping trailer every once in a while. I have tried to do a search but could never find the right thread to get a good answer. I'm am at a point in my build that it's time for final body work and an waiting to get the truck to the body shop and I wanted to airbag the truck a thought this would be a good time to get it done. I allready have drop spindles on the front and I am going to be changing an air bag system instead of springs. So any help would be great. Thanks in advance.
02-27-2012, 12:12 AM | #2 |
Re: Towing with "C" Notches
My 2000 gmc has had a bolt in c-notch for 12 years . I tow my car trailer a few times a year and have had no negative issues.
Posted via Mobile Device |
02-27-2012, 04:07 AM | #3 |
If the notch is bolted in right or welded in right it should be fine,I have seen a lot of duallies that can lay frame still tow a big heavy trailer with out any problems.
02-27-2012, 02:58 PM | #4 |
What year truck?
02-27-2012, 03:08 PM | #5 |
[QUOTE=SCOTI;5216239]What year truck?[/QUOTE
It's a 1965 C-10 Fleetside short bed. |
02-27-2012, 03:10 PM | #6 |
Andrew thanks for the info. I was a little worried about the losing strenght of the frame at the C-Notch.
02-27-2012, 03:23 PM | #7 | |
http://www.67-72chevytrucks.com/vboa...d.php?t=457037
02-27-2012, 03:40 PM | #8 | |
Thanks again, Robert |
02-28-2012, 12:54 AM | #9 |
I have seen a notch or two break in a mini truck but they was from not being welded in good.What color did you get it powder coated tho?
Thread Tools | |
Display Modes | |
