02-28-2012, 02:34 AM | #1 |
Tranny crossmember opinions
Those of you that have changed your tranny crossmembers to aftermarket ones...Could you post the goods and bads of what you've changed to. Wanting to know if they are really "direct replacements" or you gotta drill holes and add tranny mount etc. Some pics would be cool too. Was lookin at the CPP one.?! Thanks
02-28-2012, 01:29 PM | #2 |
Re: Tranny crossmember opinions
Can't help you on the tranny crossmember, but I bought all my suspension and brake components for my slammed 68 stepside from CPP and had absolutely no complaints.
02-28-2012, 05:17 PM | #3 |
A day late and $1 short...
I used the ECE crossmember seems perfect so far... didn't have to re-drill any holes or anything just bolted in.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
02-28-2012, 08:22 PM | #4 |
I have the CPP Tubular and it just bolted on with no mods
1969 Chevy C10 Shortbox SB/TH350(SOLD) 1971 GMC Sierra Grande BBC(SOLD) 1972 Chevy C20 Longbed SBC/4Speed(Sold) 1972 Chevy C10 LWB-SWB/Bagged(ALMOST) 1972 Chevy C10 Shortened/SBC(DONE) 1981 Chevy C10 SWB 383/TH350(SOLD) |
02-28-2012, 09:29 PM | #5 |
so this is the dumb question of the day our trucks did come with turbo 400 and 350 and three on trees trannys do the tranny crossmembers all mount in the same location in the frame or do they all move just a bit for ex mine had the 3 speed but im wanting the 400
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. oldno7 |
02-28-2012, 10:31 PM | #6 | |
I like the ECE x-member vs the other tubular style because they attach to the top & bottom flanges of the frame like the stock units did. I feel this offers more rigidity. I've used the ECE x-member in a 68 chassis & the holes even lined up on the frame rails using a Porterbuilt front x-member & 700r4 combo. I also just swapped one into my 89 dually w/a bbc/th400 & the holes lined up w/the later frame as well.
02-29-2012, 08:15 PM | #7 |
so is thier any perticular reason to switch to a diff crossmember over stock or is it kinda a tubular thing i dont relly see any advantage over stock
02-29-2012, 08:33 PM | #8 |
For me, the key was exhaust clearance. ECE cross-member combined with the ECE trailing arm cross-member allows the exhaust to be tucked up into the frame for lowered trucks.
02-29-2012, 10:16 PM | #9 | |
The way the factory automatic trans x-member is set-up doesn't leave much room to go above. When you route under the x-member, the exhaust becomes an area of concern w/mild to moderate drops; especially if you're running larger diameter pipe. Of course, the header/manifold configuration has to be taken in to account as well. Full length truck headers tend to hang low so exhaust routed under the x-member is about right. Shorter (3/4 length) headers, car headers, or manifolds can usually get away w/the exhaust higher up in the chassis.
Thread Tools | |
Display Modes | |
