Old 02-28-2012, 06:13 PM   #1
srea76
srea76's Avatar
what color is this in ppg codes?
I'm sure some of you have seen this truck before. I am planning to paint mine red and white also and want to go with this red color. My painter told me he could match ppg paint easily. He uses a matrix painting system. Does anyone know what color this is? Any help is greatly appreciated.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 02-28-2012, 08:22 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: what color is this in ppg codes?
I can probably find the paint codes for the '71 in the link below if you think they are close enough. I sold it shortly after I finished it but I kept the codes because I want to paint another truck the same color. It turned out great. It was PPG base coat/clear coat.
http://67-72chevytrucks.com/vboard/s...d.php?t=343754
My '39 Ford Coupe is painted with the Matrix System. It is Cherry Red. I have the number for it also...
LockDoc
Leon
Old 02-28-2012, 09:07 PM   #3
srea76
srea76's Avatar
Yep the truck looks great Leon. I looked through your post. Could you get me the ppg color code and name. It looks like it may be a little diff than the ford, but maybe it is just with the white throwing me off. Thanks so much.
1984 Silverado
Old 02-29-2012, 12:34 AM   #4
LockDoc
LockDoc's Avatar
The '71 and the '39 are different color reds for sure. I will look for the numbers in the morning.
LockDoc
Leon
Old 05-02-2012, 08:24 PM   #5
srea76
srea76's Avatar
Ever get this code for me? Paint is getting close? His truck in link. anyone have a similar color with a code? mI have paint coming soon and need to get matrix color code.
1984 Silverado
Old 05-02-2012, 09:26 PM   #6
LockDoc
LockDoc's Avatar
I didn't have any luck finding the left over paint. I must have given it to the guy that bought the truck. I did find a can of spray paint the other day when I was looking for something else, that I had made up for touch up or painting small parts. The paint I used on the truck was PPG OMNI Base Coat - Clear Coat. The information on this spray can is as follows.
Manufacturer: Queens Surface Bus Company
Brand Code: 3794 Main Layer: 3794 ALT
Oem Code: FLEET
Description: Safety Red-Maintenance
Mixing Scheme: OMNI AU (MAE)
Price Code: D
VOC Reg. 4.45 lbs/Gal
Variant:ALT (LF)
MSDS: MAE3
When you put the base coat on you will be shocked because it has a pink tint to it. As soon as you put the clear on it, it turns into the most beautiful Red you ever saw. The White is not a pure White, It is 1956 Chevrolet India Ivory. It really compliments this red paint.
LockDoc
Leon
Old 05-02-2012, 10:54 PM   #7
Zoomin
Man of Mini-Talents
Zoomin's Avatar
PPG 4230, 2011 Corvette Torch Red
Zoomin is offline   Reply With Quote
Old 05-03-2012, 07:43 AM   #8
hugger6933
If I am remembering correctly, The Torch red is a car color and Victory red is a truck color, same color different names. Something to think about because all things with the Corvette name linked to it makes it more costly.
hugger6933 is offline   Reply With Quote
Old 05-03-2012, 09:01 AM   #9
Zoomin
Man of Mini-Talents
Zoomin's Avatar
You're right, Victory Red was used on trucks, but it was also used on Corvettes on 2008. It is PPG 4154 and is a darker red than Torch.
You're right about the Corvette tax, but when it comes to paint, all reds and yellows cost more than other colors.
Old 05-03-2012, 09:11 AM   #10
Hart_Rod
Hart_Rod's Avatar
Torch red has more of an orange tint to it (especially under flourescent lights). Victory red is a cleaner/truer red. True dat on the cost! It was over $400/gallon.... I'm trying to get the paint code from my painter and I'll post the code when I do.
Hart_Rod is offline   Reply With Quote
Old 05-03-2012, 10:09 AM   #11
72peace
72peace's Avatar
Is this the chart you're looking for?
Cheers,
72peace is offline   Reply With Quote
Thread Tools
Display Modes
