Old 02-28-2012, 08:45 PM   #1
odog
odog's Avatar
WTB Front Bearing retianer sm420
I need a front Bearing retainer off a SM420 manual transmission. Retainer is 4 11/16 inches four bolt cover for input shaft on transmission.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 02-28-2012, 08:52 PM   #2
Ironhorse
Ironhorse's Avatar
Re: WTB Front Bearing retianer sm420
I may have a spare in my stash of parts in the parts shed. Will look tomorrow and do some measuring. Do you have any numbers that may help? I know I have a bearing retainer but not sure what it came from.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 02-28-2012, 09:45 PM   #3
odog
odog's Avatar
I cant get any #'s without pulling the trans. I know the retainer is 4 11/16 inches. 4 bolt holes around it
This is novacks billit design Name:  sm_420_front_retainer_b-3761982.jpg
And this is what it looks like on the trans Name:  sm420_transmission.jpg
Size:  21.1 KB. I dont know much else. I think mine may be cracked as it is leaking 80/90 out the front pretty bad, either that or the seal is bad. I would like to have both seal and retainer when I pull the trans out so I can just fix it and put it back together.
Erik
1969 4x4
Old 02-29-2012, 01:42 PM   #4
Ironhorse
Ironhorse's Avatar
Sorry but can't help you on the bearing retainer. Think mine must be for the sm465 as it is a larger at 5 1/8" dia. with four bolt holes, "GM 12" cast into it with " 3920748" stamped on the edge. Sorry to get your hopes up.
Wellington, Ks
Old 02-29-2012, 01:49 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
I may have one, I will check and let you know in a little while.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-29-2012, 02:04 PM   #6
Todd68Chevy
Todd68Chevy's Avatar
If 70Stovebolt can not help I have this http://67-72chevytrucks.com/vboard/s...d.php?t=480846 and I can measure it this evening. It was a 4 speed out of a 1967 C20 but I do not know what number it is.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 02-29-2012, 03:50 PM   #7
70STOVEBOLT
I don't have one. Todd, those parts look like they might be New Process pieces. What is the casting number on that front bearing retainer?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 02-29-2012, 09:16 PM   #8
Todd68Chevy
I really do not know what the transmission is that I got the parts off of. The transmission case looks like it has a casting #C-95948 D. I need to clean the bearing retainer up and recheck but it looks like it has a casting #97127. I measure it out at 4 5/8" diameter. I found this web site http://www.novak-adapt.com/knowledge...on_gateway.htm and it states the New Process has an aluminum top cover and this one is cast iron. It also states the SM420 was used up to 1967 and the SM465 were used 1968 and newer. I will get it cleaned tomorrow and get better pictures. Thanks
Old 02-29-2012, 11:06 PM   #9
odog
odog's Avatar
I looked at your other thread, and the pics look similar, but if you would could you post a pic of just the front retainer, front and back when you get it cleaned up? I think this is the piece, its supposed to be 4 11/16 so 4 5/8 is dang close. My trans is out of a 67 k20, I think the last year for the 420.
1969 4x4
Old 02-29-2012, 11:08 PM   #10
odog
odog's Avatar
I thank the rest of you for looking, I appreciate the effort.
1969 4x4
Old 03-01-2012, 12:06 AM   #11
Meatman
Meatman's Avatar
Sucks man. I just took a SM420 for scrap a week ago. No one wanted it.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 03-01-2012, 01:20 AM   #12
odog
odog's Avatar
Thats just the luck I have. My buddy had one in his jeep that he put in the scrap pile at work about 6 months ago. I keep kicking myself for not getting it. 3rd gear was shot but the rest was good, I didnt even think about getting it for spares. Live and learn I guess.
1969 4x4
Old 03-01-2012, 09:09 AM   #13
Todd68Chevy
Here are some pictures. There are pictures in post 5 of the thread that shows all the parts that are available. If you are interested in all of it $20.00 plus shipping or if you just want this retainer for $10.00 plus shipping. I would need a zip code to figure shipping but I thing everything but the top cover and shift forks will fit in a flat rate box for $11.35 or the bearing retainer by itself will be less. Thanks
Old 03-01-2012, 01:02 PM   #14
70STOVEBOLT
Guys, Todd's trans is a New Process 435 according to the casting number on the case.
The casting number on the front bearing retainer is for GM w/tapered bearing, 1967 according to my books. Sorry Todd, not trying to derail your sale, but if odog is positive
he has a SM420 then your cover will not work. The bearing retainer for the SM420 should have a
casting number of 3761932.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-01-2012, 01:11 PM   #15
Todd68Chevy
No problem on my end. Like I said before, I do not know what the transmission is and I do not want to sell the wrong part to some one so I am thankful for any and all help. I still have the entire transmission so I can check anything or get pictures, just let me know. Thanks
Old 03-01-2012, 02:23 PM   #16
Ironhorse
Ironhorse's Avatar
Stovebolt, can you de-code the bearing retainer I have in the 4th post to this thread? I haven't been able to find anything on it. GM 12 cast into the housing, 5 1/8" in diameter and has " 3920748" stamped into it. Would be good to know for future reference. Thanks for any help.
Wellington, Ks
Old 03-01-2012, 04:54 PM   #17
70STOVEBOLT
Can't find any info on that number. Do you have the whole transmission? If so I can probably ID it by the casting number off the main case.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-01-2012, 05:18 PM   #18
Ironhorse
Ironhorse's Avatar
Now I don't feel so bad as I couldn't find anything at all on it, LOL Don't have the tranny it came from, had it for years and don't remember how it showed up. ?? Oh well. Thanks for the try.
Wellington, Ks
Old 03-01-2012, 06:12 PM   #19
odog
odog's Avatar
todd stovebolt is right that wont work. it looks good except 4 the tapered bearing. Thanks for looking 4 me sorry we couldnt make a deal. Stovebolt thanks for catching that I appreciate it. Ironhorse that may be off a sm465 rans. those measured 5 1\8 I believe.
I just got off the phone with the guys at Novak and ordered 1 from them. didnt want to go that route very badly but kinda need to get this going. Thank you guys for looking for me.
Erik
1969 4x4
Old 03-01-2012, 06:40 PM   #20
70STOVEBOLT
No problem.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-01-2012, 10:32 PM   #21
Todd68Chevy
Sorry I could not help. I am glad that we did not make a deal on the wrong part. That does not work for either of us.
Thread Tools
Display Modes
