Old 02-29-2012, 04:33 PM   #1
Lower
Lower's Avatar
Need ideas on ls swap.
I have a 70 lwb c-10 that im going to put a 5.3 4l80 into,
Would it be better to just swap my cab and body over to the newer frame or would it be better to use the 70 frame and just get all the mounts needed to swap it over? The donor truck is a 2000 long bed reg cab. Its a 3/4 ton which is why im thinking it would be better to just pull the motor and swap it. What do you guys think?????
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 02-29-2012, 04:45 PM   #2
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: Need ideas on ls swap.
Definitely get the mounts and move the motor & trans to the 70 frame.
Lots of mount kits to chose from, I used DirtyDingo.com for my swap.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-29-2012, 05:08 PM   #3
mooseknuckles
mooseknuckles's Avatar
swap the motor and tranny into the 70.
mooseknuckles is offline   Reply With Quote
Old 02-29-2012, 06:00 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
X3 on pull the motor and trans and put in 70
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-29-2012, 10:40 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Swapping the body would be a ton more work. Are you sure its a 5.3? The only application to get the 5.3/80e were the vans, and they didn't get the newer motors untill 03. I think you may have a 6.0 there.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-29-2012, 11:03 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
or its a 4l60e...
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-01-2012, 12:39 AM   #7
Lower
Lower's Avatar
It is a 5.3, could possibly be a 60 havent pulled anything apart to find out. the truck itself will be parted/scrapped. I was looking at the motor mount towers on the new one and it looks like i could possibly surgically remove them and might make them work in the old frame? I am defineately using the 70 frame after looking at this one. Looks like its time to study up, I have a hell of a learning curve to get after on this newer stuff.
~Jon
My build thread
Old 03-01-2012, 07:51 AM   #8
Crash_OK
Crash_OK's Avatar
This site along with LT1SWAP.com and LS1Tech.com has a ton of info on how to do the swap. I am sure you have found the LS Swap FAQ on this board it is a great place to start http://67-72chevytrucks.com/vboard/s...d.php?t=456787
Good luck with your swap..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 03-01-2012, 12:19 PM   #9
Lower
Lower's Avatar
Got the truck home last night, was looking over it this morning and I think my best bet is to use the entire engine harness and just remove the sensors that I wont be using. I will be using the engine and trans, might narrow the rear end at a later date. I have the whole donor truck at my disposal. Has anyone ever used the hydra-boost setup off of one of these trucks? What about connecting it to my original steering box? I'm wanting to use everything possible from the donor truck to bring the 70 into the new ages. I think i can fab up a way to use the instrument cluster as well, I appreciate any and all criticism on what im trying to do.
Jon
~Jon
My build thread
Old 03-01-2012, 01:33 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have a hydroboost pump in mine, but haven't hooked into the brake circuit yet. You can cut the fitting off of the line, and flare the old style fitting on to use with your pump.
Old 03-01-2012, 03:34 PM   #11
Clyde65
Clyde65's Avatar
Get with Captnfab, he makes a mount for the Hydro brake that fits to the earlier trucks
Clyde65
Rebuild of Clyde
support our troops!
Thread Tools
Display Modes
