03-03-2012, 11:59 PM | #1 |
'88 Suburban front end for disc brake conversion in '70 1/2 ton?
Hey,
Just wondering if I can use the front end out of a 1988 burb to bolt up to my '70 pickup so I have frot discs? Is the swap the same as using 73-87 front end parts for the conversion? Posted via Mobile Device Last edited by JON70CST; 03-06-2012 at 04:18 PM. |
03-04-2012, 12:57 AM | #2 |
On the fast track to nowhere..
Re: '88 Suburban front end for disc brake conversion in '70 1/2 ton?
It should work fine. The Suburban carried the same design to 1991.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
03-06-2012, 04:16 PM | #3 |
He threw in the steering box, linkages with tie-rods and everything from the 88 burb as well. Will this all bolt up as well, and eliminate the need for me to run a conversion sleeve for the tie-rods etc.? Sorry I'm new to this conversion. My truck already has power steering if that makes a difference?
03-07-2012, 01:33 AM | #4 | |
Thread Tools | |
Display Modes | |
