Old 03-05-2012, 08:48 PM   #1
chronos
Dome light help
Does anyone know where the orange and whit wires that come from the dome light attach? Mine got caught up in my grinder a while back and I can't figure out where it goes!
Is it into the headlight switch?
My little light at your feet still works by the way
chronos is offline   Reply With Quote
Old 03-05-2012, 09:43 PM   #2
jhngardner367
jhngardner367's Avatar
Re: Dome light help
HI,Chronos! Here's a wiring diagram for '73-87.Hope it helps!
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-05-2012, 09:48 PM   #3
chronos
Re: Dome light help
Hi thanks , I could never make head or tails of those diagrams
All I see is the end of the wires sitting on my cab floor and Have no clue where they used to go
Old 03-05-2012, 10:05 PM   #4
jhngardner367
Re: Dome light help
Give me 5 minutes,andI'll run out & check on my truck.I THINK the white goes to the light switch,and the orange SHOULD go to the fuse blck.
I have an orange wire,and a white wire that comes from the dome light ,under the carpet,and direcly to the back of the fuse block.
Old 03-05-2012, 10:58 PM   #5
chronos
Re: Dome light help
Back of the block??Wonder where it goes to back there?
Old 03-05-2012, 11:13 PM   #6
|ow|ife
|ow|ife's Avatar
Re: Dome light help
if all you did is slice through the wire with a grinder shouldn't there still be orange and white ends near the fuse block where you can see the ports?
it's not what you buy, it's what you build
use your skills, not your wallet
|ow|ife is offline   Reply With Quote
Old 03-06-2012, 01:30 AM   #7
jhngardner367
Re: Dome light help
Not if they wrapped around the grinder,and it pulled them out. Either way,you'll have to disconnect the battery,and remove the inner side of the fuse bloc,to seewhere they were connected.Then,simply recrimp the wires back into the ends.
Give me a couple of days,and I'll pull the fuse block out of my GMC,and post a pic of it.IT should confirm where they go.
Old 03-06-2012, 10:14 AM   #8
chronos
Re: Dome light help
That would be great! Nice to get this figured out.
The wires did get wrapped up in the grinder and gave me a nice gash in my leg in the process! Should have been more careful...lesson learned.
Old 03-06-2012, 12:42 PM   #9
Corts60
Just here to tinker
Corts60's Avatar
Re: Dome light help
Follow the wires from the light that works at your feet to find the orange wire as they are connected together at some point. The white one is a ground that usually connects to the door jamb switch that operates it.
Old 03-06-2012, 08:40 PM   #10
hatzie
Moderator
hatzie's Avatar
Re: Dome light help
The white wire also attaches to the headlight switch as well.
Old 03-23-2012, 11:28 AM   #11
chronos
Re: Dome light help
Thanks everyone , it is hard for me to track down where those wires came from. I have looked everywher under the dash area for a place where it looks like something was ripped off of broken and can't find anything?
If anyone has a picture of the orange and the white wires actually going where they belong would help alot
Old 03-23-2012, 02:25 PM   #12
Corts60
Just here to tinker
Corts60's Avatar
Re: Dome light help
I'll see if I can snap you one this morning.
Old 03-23-2012, 08:49 PM   #13
chronos
Re: Dome light help
That would help alot.
Just one of those little things I wanna get fixed!
Old 03-25-2012, 10:02 PM   #14
chronos
Re: Dome light help
Still hoping for a pic to finish this finally
Thread Tools
Display Modes
