aka Crusher, Crushergmc
I'm contemplating putting a stock trailing arm set up on my Jimmy. I want the handling and bagging advantages. Looking at a friends, it looks like I can get the arms, crossmember and maybe brake lines. Is that it? Will I have problems due to the short wheel base of my Jimmy (I know my Jimmy's short LOL).
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" Last edited by 70 Jimmy; 05-04-2003 at 06:01 PM. |
I don't know if there are two different sizes of trailing arms, I doubt it. Anyway my factory 2wd Jimmy has trailing arms.
I've found thats theres only one trailing arm length. What about the frame panhard bar mount? You'll need to get that and probably get the extended panhard bar kit from ECE so you can attach it to the trailing arm cuz your rear end probably doesn't have the provision for it
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
That makes since. I'm also wondering about the frame. I believe the 4x4 Jimmy/Blaze is different. I'm wondering if a stock crossmember will work or should I fab one????? Thanks for the help guys, keep it coming!
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
Can anyone help?
I have my chassis out in the garage. I'll get you a pic so maybe you can compare.
Here are a few. Hope they help.
#2
#3
If there is some other angle you need just let me know.
Member since 2000
i thought the bend in the frame where the coils hook up too is where the the 4x4 frames differ.... Maybe some measurement can help you out. Tell me if you need any I'll be glad to help you out with this info cause I am also curious of what must be done to switch.
edit: some pictures.... ![]() ![]() ![]() Last edited by Alexis; 05-05-2003 at 06:28 PM. |
Looks like all I need is the crossmember. I may have to modify it, but it looks straight foward. It will be awhile before I'm ready to do this. I'll post pics when/if I do it. Thanks a ton for the pics!
#13 |
Come on guys, no one else has done this or thought about it? I guess all I really need to know is if the rear part of the frame is different between the two Jimmy's/Blazer's (2wd vs 4x4).
Thread Tools | |
Display Modes | |
