Old 05-03-2003, 08:09 PM   #1
Alexis
Member since 2000
Alexis's Avatar
HEI knocking sound
I just finished installing a HEI. it starts up and i get the timing sometime near pefect but there is this wierd knocking sound that happen when i lay on it, sometimes a pop. do you have any idea what this might be?
oh i also didn't use a 12 gauge wire I used a 14, can this effect it?
Alexis is offline   Reply With Quote
Old 05-03-2003, 09:17 PM   #2
MOTHERTRUCKERS
Run a temperary 10 gauge wire from your battery to the hei and see if that fixes your poping problem.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-03-2003, 09:23 PM   #3
BAD4X4
BAD4X4's Avatar
The rotor might be rubbing on the cap, I know my old 69 did the same thing, and it was the rotor rubbing.Hope this helps.
BAD4X4 is offline   Reply With Quote
Old 05-03-2003, 10:37 PM   #4
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Yeah, check to make sure that the cap is locked down properly, mine had one of the locking tabs improperly seated, and when I started the truck it would make a knocking sound and when reved up it would misfire.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 05-03-2003, 10:59 PM   #5
Alexis
Member since 2000
Alexis's Avatar
what if the rotor is cracked where the screw holds it down?
Ok I messed with the timing and I was way off. But it seems i can't really drop the timing any lower cause the engine seems to kick a little. Any one know what this kick means?
thanks for your help guys.
Old 05-04-2003, 01:00 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
If the engine is fighting the starter, it is either retarded or advanced too far......I can't remember because it's been awhile since I messed with one. I do know if it's advanced too far, it will ping when you hammer on it. The cracks in the rotor aren't helping your situation any. They can cause the spark to go to ground in places it shouldn't and also slow the timing down and make it run like crap, same as cracks in the cap will.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-04-2003, 09:47 AM   #7
jmanz69
Careful, they attack...
jmanz69's Avatar
Go to the autoparts store and get a new cap without a crack in it. Why use a broken part when a replacement is cheap!!! Then run a bigger wire to the coil, and then set your timing. If your not going to do it right, then don't do it. And don't ask why it doesn't work with an improperly installed unit... If you are going to do it half-a$$ed, then don't wonder why it's not working like it should.
jmanz69 is offline   Reply With Quote
Old 05-04-2003, 10:35 AM   #8
gmc67swb
gmc67swb's Avatar
WHY DON'T YOU TELL HIM WHAT YOU REALLY THINK!
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 05-04-2003, 01:08 PM   #9
jmanz69
jmanz69's Avatar
Sorry, I was in kinda a crappy mood this morning. I guess I was a little hard on him. Also, he should check to make sure there isn't a advance weight hitting the cap as it speeds up. Could have a broken spring there, it would also make his timing different.
Alexis,
Sorry for being rude, but you have to install things right, then ask why it doesn't work. Take away all known weak areas such as the 14 ga wire, and the broken hold down tab on the cap.
I hope you get it going, good luck!
Thread Tools
Display Modes
