Old 03-08-2012, 06:59 PM   #1
Nordic
Nordic's Avatar
gas tank location... where?
Time to decide where to put the gas tank(1958). Do I keep it in the cab or move it to under the bed? Let me know which you prefer and why?
Nordic is offline   Reply With Quote
Old 03-08-2012, 07:03 PM   #2
memo43
memo43's Avatar
Re: gas tank location... where?
I have mine under the bed.
No more gas odors in the cab, plus gain extra storage behind the seat.
being under the frame, fills up unused space plus, helps transfer weight to the rear end.
Memo S.
Retired US Marine
Family Man
memo43 is offline   Reply With Quote
Old 03-08-2012, 07:25 PM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
I haven't done mine yet but I absolutely will. Burning to death trapped in a wrecked truck is NOT my idea of the way to go!
The rubber hoses that connect the tank to the fill & breather tubes are usually hard as a rock after 50 years and shatter in a significant collision spewing gas all over the interior. Mate that up to the typically compromised 50 year old wiring insulation and its a no brainer for me.
Chuckdriver did his using a generic tank from Tanks, Inc and I plan to copy his install:
See HERE for how he did his. First rate job! Post #114 for a photo and somewhere in his thread is a discussion of the parts he used and a photo of the filler.
http://67-72chevytrucks.com/vboard/s...=334552&page=5
Dan in Pasadena is offline   Reply With Quote
Old 03-08-2012, 07:31 PM   #4
B_Hix
B_Hix's Avatar
^^ ditto. I have a poly cell under the bed - the weight is useful and I'd much rather have it back there of something bad were to happen...
B_Hix is offline   Reply With Quote
Old 03-08-2012, 07:34 PM   #5
1953chevyroc
1953chevyroc's Avatar
'66-70 mustang tanks are popular in these trucks. They're cheap, and have the fuel fill on the top.
1953chevyroc is offline   Reply With Quote
Old 03-08-2012, 08:39 PM   #6
justplainray
justplainray's Avatar
here is a thread from a few months ago on this very subject.
http://67-72chevytrucks.com/vboard/s...d.php?t=499935
justplainray
justplainray is offline   Reply With Quote
Old 03-08-2012, 10:04 PM   #7
Dan in Pasadena
Ray,
Your install looks smart. Did you get a junkyard tank or did you buy a repopped tank?
Looks like you just cut a short section out of the filler tube and reattached the ends with a rubber hose & clamps. Is that correct?
Does the vent tube actually send much gas to the "Fluid Separator" i.e. Radiator overflow tank? I'm wondering if you ever have to drain it or if it just catches minor slosh that evaporates?
Old 03-09-2012, 12:50 AM   #8
_Ogre
_Ogre's Avatar
frame mount is the way to go. My first choice would be a panel tank, they are as rare as hen's teeth. I have a tank from no limit engineering. Little pricey. Some have used the mustang tank with good results.
shop air compressor timer
Old 03-09-2012, 01:00 AM   #9
Daze57
Daze57's Avatar
under frame mount definetly !-dont need da fumes from either kind of gas !
Daze57 is offline   Reply With Quote
Old 03-09-2012, 09:39 AM   #10
justplainray
Dan,
Thanks, I bought a new tank from an on-line auto parts retailer. can't remember who.
and yeah, just cut out a section of filler neck and used rubber hose and clamps to reattached. Boy! that section of fuel filler hose was pricey, as I remember it.
And I am sure that liquid fuel gets into the overflow bottle, which is why the tank vent line goes into the very bottom of the bottle and the bottle vent is at the very top. That way the liquid can reflow back into the tank as the pressures equalize.
justplainray
Old 03-09-2012, 11:07 AM   #11
Speedbumpauto
Speedbumpauto's Avatar
Poly tank from Tanks for early 50's Ford passenger car. Relocate rear crossmember to rear of frame for easy fit. 17 gallons. I wanted a fill door in the driver rear fender that would fill easily, not in the bed.
Speedbumpauto is offline   Reply With Quote
Old 03-09-2012, 01:35 PM   #12
55metalmonkey
I relocated mine to the rear frame under the bed useing a poly tank, I'll be building a custom alum one soon just because I always seem to change my mind after I get something accomplished
I figured that I get more cab space for seats/ consol/ speakers/ storage, no gas fumes as I drive around on a nice hot sunny day and the big one for me is that it's safer. I'm not so worried about being snuffed out in a naplam like fire ball if I was in a huge accident, it's living through the aftermath if I survive.
just my 2 cents
55metalmonkey is offline   Reply With Quote
Old 03-09-2012, 01:42 PM   #13
Dan in Pasadena
I like ChuckDriver's and Ray's but yours has some VERY nice features too. Best is the cross member relo makes you still able to have a receiver hitch in it - I could use that.
BTW, is that frame powdercoated? Cause if its not I want to know what kind of paint that is? Thick and glossy, looks awesome.
Old 03-09-2012, 05:42 PM   #14
Speedbumpauto
The roll pan license plate will cover the receiver hitch when not in use and I might never use it but I decided it should be there, especially invisible, if I ever want to tow something. Yea, I sprung for the powder coat.....and I love it. I'm running EFI and the Tanks folks have an in tank HP fuel pump that bolts right in to that tank. That sold me!
Old 03-09-2012, 06:28 PM   #15
nacho55
I have a repoped blazer tank from a 87-90 fullsize at the rear of mine, I think it was also in a tech article in one of the truck books a few months back, its a little big but fits nice, If your doing fuel injection get the 87-90 if not get a little older one for the mechanical pickup.
nacho55 is offline   Reply With Quote
Old 03-09-2012, 06:31 PM   #16
jimig1
jimig1's Avatar
I did the same thing in mine. I found a brand new tank on CL for $50 so i could not pass it up. here is a link to the article http://www.classictrucks.com/tech/11...ank/index.html
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 03-09-2012, 06:52 PM   #17
nacho55
That's the one, I made my own straps out of some 2" strap material and old bike tubes to insulate the tank worked out pretty good
Thread Tools
Display Modes
