Old 03-09-2012, 11:35 AM   #1
Jaymans82
Jaymans82's Avatar
Building a 383 looking for tips
Hello All
My name is Jason and I'm looking for tips in what kind of heads to use on a every day driver 383 motor 30 over with a 268 cam.
Jaymans82 is offline   Reply With Quote
Old 03-09-2012, 01:39 PM   #2
classic70
classic70's Avatar
Re: Building a 383 looking for tips
If you are on a budget go vortec heads. This will require a different intake manifold specific to the heads. With vortec heads and that cam you should be around 385-400 horse depending on your compression ratio. The vortecs are 170cc intake runners and 67cc combustion chamber. 1.94 intake and 1.5 exhaust. if you want to spend a little more money go GM bowtie heads.
classic70 is offline   Reply With Quote
Old 03-13-2012, 02:06 AM   #3
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
I have world product sportsman ll heads make around 430-440 horse street driven there a pretty penny though
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 03-16-2012, 01:09 PM   #4
Jaymans82
Jaymans82's Avatar
I got some 882 heads here are the DETAILS
Heads are thoroughly cleaned and inspected
Pressure tested to ensure no cracks or leaks
3 ANGLE Valve job / Pocket Ported under valve seats
CBN milled to ensure straightness within .0015" and correct finish
All machine work performed on the latest state of the art equipment
Heads are assembled with new stainless 2.02 swirl polished intake valves
Heads are assembled with new stainless 1.60 swirl polished exhaust valves
Heads are machined with new hardened exhaust seats for unleaded fuel
Heads are assembled with hardened valve keepers
Heads are assembled with new .500 lift Z-28 valve springs
Heads are assembled with new valve seals
Heads are complete and ready to install
Old 03-17-2012, 10:14 AM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Heres my tip for building a 383, DONT. Its going to sound good but get 6 mpg if you're lucky. Put a cam in a 5.3 or 6.0, make same or more power with stock everything but the cam, and get 20 MPG at the same time. You can do the injected motor for the same price or cheaper than a 383 with good internals.
--Josh
Old 03-17-2012, 02:14 PM   #6
Jaymans82
Jaymans82's Avatar
Man I didnt want to hear that!!!!! Block is almost done and heads will be here monday. Right now the truck has a 350 with 305 heads on it. I baby the crap out of it. Some days it knocks more then otheres and I have a hard time pulling a trailer are camper. I was told a 383 is the way to go if I want the pulling power..
Old 04-12-2012, 12:01 PM   #7
Jaymans82
Jaymans82's Avatar
Here it is started it for the first time for the break in......
http://[/IMG]
Old 04-14-2012, 09:51 PM   #8
Can't kech me
Can't kech me's Avatar
i agree.
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 04-19-2012, 05:29 PM   #9
Jaymans82
Jaymans82's Avatar
Thanks for the tips guys, But think I will do a little better then 6 mpg with a 4 speed transmission.
Old 03-20-2013, 01:01 PM   #10
Jaymans82
Jaymans82's Avatar
I put a 700R4 transmission the my truck and people are telling me if the tv cable isn't set right i will burn up the transmission. Can anyone tell me how can I tell if its not set right.
Old 03-21-2013, 04:39 PM   #11
stroker87
6mpg? man what did you have? My 383 stroker was getting 13 to 17mpg and it was never tuned 100% i know others that was getting over 21mpg
383+700r4+3.73= 15mpg average more if i'd keep my foot out of it lol
but i will agree a LS is cheaper these days and more power when I built mine back about 4 years ago it was to costly now its much cheaper
stroker87 is offline   Reply With Quote
Old 03-22-2013, 09:39 AM   #12
Jaymans82
Jaymans82's Avatar
What size Carburetor are you running with that set up?
Old 03-22-2013, 09:23 PM   #13
stroker87
mine is Fuel injected but I know a couple guys that ran 750's carbs and one ran a 650
Old 05-31-2013, 11:49 AM   #14
Jaymans82
Jaymans82's Avatar
my holley 750 double pumper, double feed, 4 corner idle is running rich at idle. i went from a 6.5 PV to a 3.5 PV to a plug and it has 71 jets for the primary's. and the floats are set right. Can anybody help. Please
Old 05-31-2013, 11:56 AM   #15
manimal
manimal's Avatar
Need more specifics on your engine. I had a 383 in a '76 K20 with a 6" lift and 35's w/ 4.10 gears. I got 11mpg. I had WP Sportsman II's, dished KB hyperutectic pistons and a Comp X-treme 4x4 cam. th thing would light up the 35's and like I said I got 11mpg.....with a crappy edelbrock 600cfm carb. I think your 750dp is too much.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-31-2013, 02:06 PM   #16
Jaymans82
Jaymans82's Avatar
it a 383 with a 292 cam the head details are on the fourth post from the top. this is in a 82 chevy C 10 with I think 308's gears. I had a holley 600 on it and it was rich to with a 3.5 PV in it. The 750 is a little better with the pv plug but I still smell it when im backing up. and have only put like 4 miles on it...And it is the same spark plugs.
Old 05-31-2013, 05:37 PM   #17
manimal
manimal's Avatar
What compression, which 292 cam? What is your timing set at? What plugs?
-Lance
Old 06-06-2013, 03:50 PM   #18
Jaymans82
Jaymans82's Avatar
I don't know what cam. I know the duration on the cam is 234 degrees and its from Jeg. The timing is set at 12 degrees and the plugs AC Delco R45TS gaped at 30. Just found the cam on Jeg site http://www.jegs.com/i/JEGS+Performan...00006/10002/-1
Old 06-07-2013, 07:04 AM   #19
naphtali5725
naphtali5725's Avatar
at wide open throttle (WOT) the tv cable should be pulled tight
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 06-28-2013, 04:38 PM   #20
Jaymans82
Jaymans82's Avatar
Help!!!!!!!
Old 06-28-2013, 04:40 PM   #21
naphtali5725
Help!!!!!!!
help what?
there are video's on youtube on how to adjust a tv cable...
My build thread...
Disabled Veteran
Old 07-01-2013, 10:14 AM   #22
Jaymans82
Jaymans82's Avatar
This is what i'm asking help with! Thanks
Old 11-06-2013, 06:19 PM   #23
Jaymans82
Jaymans82's Avatar
Ok need some help for a good carb that wont run so rich. I have a 383 40 over with a 292 cam, air gap intake, with 1975 882 cast iron heads port and polished 2.02 intake and 1.60 exhaust. And a 700R4 transmission. In a 82 chevy truck long wheel base.
Thanks Jason
Old 11-07-2013, 10:26 AM   #24
Hertzdaddy
750dp may be a little too much carb but running rich at idle is not a PV problem. The PV has no effect on idle mix. Its all in the idle circuit.
What vacuum do you have at idle? How is transition from idle to cruise? There are a number of ways to adjust your idle mix but they have to be done in the right order. Here is a good article on an 850dp (very similar to 750dp). It explains the steps fairly well. http://www.carsandparts.com/Articles...r-barrel-carbs
Hertzdaddy is offline   Reply With Quote
Old 11-07-2013, 10:52 AM   #25
Hertzdaddy
The first link I posted may be a little too advanced for what you need. Here is another one that is a little simpler. http://www.dragzine.com/tech-stories...rbureted-cars/
You can find many other articles on the subject too.
You may be better off with a Holley street carb in the 650cfm range with vac secondaries. An Edelbrock in the same range would be an ok choice too. The dp's tend to work best for lighter cars, higher gears (low #) and more radical cams or some combination of those. They are not known for their economy though (i.e. rich).
Let me know if you ever want to sell the 750, btw.
Thread Tools
Display Modes
