Old 03-09-2012, 08:47 PM   #1
hopped up
hopped up's Avatar
Pulled my tranny
Pulled my tranny cuz Ive been trying to find out why I keep going thru starters. I decided it must be be a problem with my flywheel. I didn't put the motor/tranny in. It was just sitting there. Anyways there's a bolt missing and all but two of the bolts were loose. I assume I found my problem. I'm still gonna put in a new flywheel and quality flywheel bolts. Any suggestions? Loctite? What's the torque! Arp bolts!any help will be appreciated,also gonna install a shiftkit(b&m) should I do 1st stage or 2nd? It's just a driver and to have fun in.thanks
hopped up is offline   Reply With Quote
Old 03-09-2012, 08:58 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Pulled my tranny
What engine and transmission do you have?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-09-2012, 10:07 PM   #3
hopped up
hopped up's Avatar
Oh yeah forgot, 350/th350
Old 03-10-2012, 11:52 AM   #4
Rich 5150 69
Rich 5150 69's Avatar
When you get you`re now starter flywheel they only go on one way, they are marked, they set you`re then shim you`re starter if needed, and get new bolts from ARP, as far as the shift kit I`d go with the first stage unless you`re trans has been upgraded. happy trails....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-10-2012, 12:13 PM   #5
oldgoalie
Had one a long time ago that kept eating starters. After about the third starter I found out the advance weights where sticking full advance in the dist. Got those fixed never had another starter problem. Just something to look at. I like to use the Transgo shift kits, a -1, or green box we call them. They work good and are easy to install.
oldgoalie is offline   Reply With Quote
Old 03-10-2012, 12:41 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
That's interesting. How did the advance weights have anything to do with the starter/flywheel alignment?
Old 03-10-2012, 12:58 PM   #7
hopped up
hopped up's Avatar
Thanks or the responses,got a new flywheel ,new flywheel bols,gonna install the stage 1 shiftkit then get on the flywheel,tranny install. What's the toque specs on the flywheel bolts? Do I use loc tite on the flywheel bolts?
Old 03-10-2012, 01:01 PM   #8
oldgoalie
Hey Cort2s60
The timing was to far advanced, it would seem to work fine, than once in a while, the engine would kick back (for lack of a better term) because it was so far advanced. Older engine, higher compression than todays engines. One time it actually busted the head of the starter off. I always tought it was the starter going bad or bad starters. The weights were stuck for good when I was replacing the last starter. Just couldn't get it to work right, so I just started checking other things and came across the the fast timing and stuck weights. Have seen the problem a few times since than. I have a trans repair shop and replace lots of flex plates, something I always check. Don't see it to much any more with all the new stuff out. Some of the throttle body trucks have dist. problems and will do it also.
Old 03-10-2012, 01:14 PM   #9
jayman68
Fun Stuff
jayman68's Avatar
The torque on the bolts should be around 65-75 lb/ft, and definitely use loc-tite.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 03-10-2012, 10:21 PM   #10
hopped up
hopped up's Avatar
Angry Re: Pulled my tranny
Well just finished putting the tranny back in and everything else that goes with it ! Took me about 8 hrs alone!!!! And guess what? The exact same ****!!!! Im planning on taking it on the cpp cruise but damn I'm pretty pissed tonite! I'll get back on it in the morning but I'm exhausted and pissed!! I know I'm done for tonite! After the tranny fell on my head!!! Hahaha!!! It'll turn on but the grinding is still there I shimmed it on each side to see what happens and it still grinds. I'll do some ore investigating tomorrow
Thread Tools
Display Modes
