Old 03-11-2012, 03:44 PM   #1
mm1077
Active Member
mm1077's Avatar
70 C10 lowering questions
Just wondering if anyone could give an opinion on if I'm headed in the right direction on lowering my 70 C10 lwb (I've read a ton of info on here and online but just want to be sure before I start ordering stuff)...
I have new 275/60/15 all the way around, looking at 4" drop springs for the rear (could I just add a 1" block if I wanted to go lower?) and a set of drop shocks...I was just going to cut 1 coil off of the front and use drop shocks (or relocate the current shocks) + alignment. Any opinions on whether I would run into clearance issues w/ the 275's on the front w/ just cutting the 1 coil? Anything else that I would absolutely need to make this happen? Or anyone have pics of a similar setup w/ the 275's on all four too that would be awesome...
mm1077 is offline   Reply With Quote
Old 03-11-2012, 04:05 PM   #2
AustinScott
AustinScott's Avatar
Re: 70 C10 lowering questions
Here is some a helpful thread. this is my truck & it has 275/60/15 on all 4 corners
SImple Coil Cut Front Drop
Currently I just installed all new stuff when I switched over to disks and I'm still running 275/60/15 on all four corners.
I have 5" drop springs in the rear now, no clearance issues, But I have to same you need an adjustable panhard bar, so you can even out the rear-end.
I tried mine with the stock bar, just so I could post info of "if it works or not" and my rear driver tire would rub on the inner wheel well on bumps & hard turning.
I installed my adjustable pan-hard bar and centered my rear-end, and I have about 1" of clearance on both sides between my tire and the inner wheel well. This is on 15x8" with 4" BS
Hope this helps...
-=scott=-
AustinScott is offline   Reply With Quote
Thread Tools
Display Modes
