Old 03-11-2012, 10:13 PM   #1
Chevy Iron
Chevy Iron's Avatar
Front Brakes LOCKED!
Replaced the master and have the same issue. Third time on the brake pedal, the fronts are dragging and continue to do so until they are locked (all parts are new).
Opening the line at the master cylinder releases all pressure on the calipers.
Any advice? Thanks guys.
Chevy Iron
Fully customized 1968 C-10 Stovebolt 292, T-5 trans 3:73 posi
Wife says it's a "midlife crisis".....I'm okay with that.
Chevy Iron is offline   Reply With Quote
Old 03-11-2012, 10:27 PM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Front Brakes LOCKED!
Any time I have locking brakes its the brake hoses collapsed.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 03-12-2012, 04:36 AM   #3
oldspowered67C10
Check the length of the push rod between the booster and the master cylinder(assuming this is power set-up). If the rod is too long it wont allow the pressure to bleed back when you release the brakes.
oldspowered67C10 is offline   Reply With Quote
Old 03-12-2012, 07:35 AM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i would check to see if the PV is off set
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 03-12-2012, 07:42 AM   #5
dennislbrooks
dennislbrooks's Avatar
As OLDS says --- Check the length of the push rod between the booster and the master cylinder(assuming this is power set-up). If the rod is too long it wont allow the pressure to bleed back when you release the brakes.
You cannot preload the master cyclinder. You rod should be adjustable.
This happened to me and had to get a roolback to get it home.
dennislbrooks is offline   Reply With Quote
Old 03-12-2012, 05:34 PM   #6
Chevy Iron
Chevy Iron's Avatar
Not sure what you mean by offset?
Chevy Iron
Old 03-12-2012, 05:36 PM   #7
Chevy Iron
Chevy Iron's Avatar
This is not a power booster setup but nevertheless, pedal rod was adjusted to be just snug to the master.
Chevy Iron
Old 03-12-2012, 05:37 PM   #8
Chevy Iron
Chevy Iron's Avatar
Would an adjustable proportioning valve work albeit reversed? Or is this not where the problem lies?
Chevy Iron
Old 03-12-2012, 07:40 PM   #9
cdowns
cdowns's Avatar
there should be 1/8- 1/4 inch clearance to prevent drag
Old 03-12-2012, 08:40 PM   #10
Chevy Iron
Chevy Iron's Avatar
Could the difference of a 1/4" rod play make the fronts lock?
1/4" of play and the rod is out of the "socket".
I am curious though...I did not check the rod pressure or gap after bleeding, would it change?
Chevy Iron
Old 03-13-2012, 07:35 AM   #11
cdowns
cdowns's Avatar
the clearance is what is reccomended in the GM service manuals i have// they reccomend 1/16-1/4 actually
i believe it gives the plunger a chance to fully "spring" back and fully release the brakes
Thread Tools
Display Modes
