Brakes??
My brake light is on.....what is the most common cause of this?? What should I check first? Fluid looks fine!
Re: Brakes??
The E-Brake can be "on/slightly depressed"
![]() Join Date: Sep 2005
Re: Brakes??
ebrake on or low on fluid
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: Brakes??
it may also be a blown wheel cylender or caliper. There is a pressure switch in your proportioning valve that can also go if the O rings are shot.
Re: Brakes??
mine has been on forever and i finally stopped caring. I mean i looked and looked and looked and i could not find anything wrong. Even took it to Les Schwab and got a shrug! My abs light comes on with it. and you know if the abs light is on you can narrow it down to 6 or 7 dozen things!
2001 Tahoe 1978 K30 |
Thread Tools | |
Display Modes | |
