Old 03-23-2012, 11:34 AM   #1
chronos
Vacuum line help
Trying to clean up my vacuum lines as they are all falling apart. I have attached a pic and am wondering if you need that moulded black thing (orange arrow) and the connectors (green arrow) or can the line rund right out of the grey tee and into the spot they go?
Hope I explained that....lol
chronos is offline   Reply With Quote
Old 03-23-2012, 11:50 AM   #2
beamn7
Re: Vacuum line help
Orange arrow: no, you can just connect the hoses directly to the thermal vaccum switch but the molded connector sometimes is nice so as to be sure each hose is connected correctly next time they are disconnected....
Green arrow: Depends. If you still have to emissions test your truck, then yes keep it. If not, then no, you can remove it. It is a spark delay valve for the vaccum advance on the distributor....
beamn7 is offline   Reply With Quote
Old 03-23-2012, 01:30 PM   #3
chronos
Wow Thanks for that,I would have never know that the green arrow did anything at all and was a spark delay valve. I do not have any emissions crap anymore-no egr,vacuum canister,etc, So that can be removed and a hose run straight to the vaccum advance?
Is that moulded connector available anywhere? The one I have now has 4 coming off it but 1 is already pluged and 1 of the other ones just looks to loop back to itself. I think I could get by with a connector that had 2 coming off it
Old 03-23-2012, 02:24 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Since I do not have any emissions testing in my area. I ran one hose off of the intake manifold and put the connections for the vacuum hoses on my firewall and cleaned up the engine a lot.
Frank
piecesparts is offline   Reply With Quote
Old 03-23-2012, 02:25 PM   #5
beamn7
Yes, you can remove it and run the hose directly to the dist. As far as the connector, not sure if they are still available. I'd just connect the hose(s) directly to the thermal vaccum switch...
Old 03-23-2012, 03:14 PM   #6
brownbag40
brownbag40's Avatar
I am wondering if you could get those hose new too. If anyone has a part number they could post.
brownbag40 is offline   Reply With Quote
Old 03-23-2012, 05:04 PM   #7
hatzie
Moderator
hatzie's Avatar
If you're motivated you can make disposable molds and cast them out of Devcon Flexane or similar Castable Silicone or Urethane. "Medium hard" 40-60 durometer is what you're looking for. You can get these chemicals in small lots from McMaster Carr. I've done this with "out of production" small rubber parts that had hardened up. Don't expect "Professional" looking results on your first try but you can probably get serviceable parts after a couple tries.
Some reading if you're interested.
The Vince Gingery "Plastic Injection Molding" how-to texts from Lindsay Books.
Google Books"How to Cast Small Metal & Rubber Parts"
Last edited by hatzie; 03-23-2012 at 05:21 PM. Reason: Add source of Castable Urethane
Old 03-23-2012, 05:45 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
yup cleans real ez with no etest
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-23-2012, 08:50 PM   #9
chronos
Looks like I can finally get that cleaned up.
I think I will just get rid of the tvs all together.
What can the vaccum advance hose go to without that??
On the carb??
Old 03-23-2012, 09:10 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
On the carb??
same place just bypassed
John
Old 03-25-2012, 10:01 PM   #11
chronos
Thanks for all the help with this.
got everytning done today and am no longers using th tvs
truck runs better than ever!
Just need to swap out the inlet now for a non-tvs one maybe go chrome
Old 03-27-2012, 05:57 PM   #12
kody
my truck does have smog pump or egr valve conected,can i take off vacuum canister?truck only gets saftey inspection.
kody is offline   Reply With Quote
Old 03-27-2012, 06:47 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
"Dosn't"?
Yes you need a vent cap for it then
Doing that with my 79
John
Old 03-27-2012, 09:16 PM   #14
kody
does anyone know where i can buy vented gas cap? i would like to get that mess out of there,thanks.
Old 03-27-2012, 09:38 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
No ,it's a small cap like for the diff to keep dirt out, bolt it where the can was
John
Old 03-27-2012, 09:51 PM   #16
kody
can you send photo when you finish with yours?,thanks.
Old 03-27-2012, 11:34 PM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
sure
my 78 is like that now
and how the 79 was
John
Old 03-28-2012, 06:57 AM   #18
kody
thanks, motornut.
Old 03-28-2012, 03:08 PM   #19
kody
now,wonder where i can find one of those little vent caps?
Old 03-29-2012, 09:51 AM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
most parts places will have them
John
Thread Tools
Display Modes
