Old 03-24-2012, 09:52 AM   #1
slam59
Replacing freeze plugs,painting engine area..
On my 74 C10, gonna have all my freeze plugs replaced, and the following gaskets/seals replaced-front main seal and rear seal,valve cover gaskets,rebuild kit for my Edlebrock carb, and since my motor is being pulled out for the freeze plug replacing, its gonna get degreased and painted. The 74's originally had the motors painted reddish orange correct? Was thinking about painting it black since the fenderwels and other areas are already painted black. And as time goes by little by little i will be adding and replacing things and getting them in chrome so they will stand out against the black. But I really like the look of the reddish color on the motor when done right. How about some pics of the motors some of you all have so I can check out how they look in different colors for those of you that have theirs painted.
slam59 is offline   Reply With Quote
Old 03-24-2012, 10:51 AM   #2
bayou boy
bayou boy's Avatar
Re: Replacing freeze plugs,painting engine area..
not mine but cool
all i know is that its going to be orange
bayou boy is offline   Reply With Quote
Old 03-24-2012, 11:36 AM   #3
slam59
Forgot to mentiom, which brands/paints hold up? Thanks.
Old 03-24-2012, 01:53 PM   #4
54Caddy
GM Addicted
54Caddy's Avatar
Heres mine man. On my 350 i went with all black. Its duplicolor engine paint it stands up well, i dont paint over freeze plugs like the natural look of them. It has an edelbrock endurashine intake just need the endurashine carb. Its not really clean under hood but its something.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-24-2012, 01:55 PM   #5
54Caddy
GM Addicted
54Caddy's Avatar
Heres some of the stock 305 when it was fully rebuilt with all smog equipment and the 2 barrel carb. Then changed intakes and carbs. On the 305 i painted the block black and the heads the cast aluminum color. But the silver didnt hold up as well as the black. They also sell a clear that might have helped it. Just a few pics man
..Mac’s Garage..
IG:MacsGarage
Old 03-24-2012, 09:53 PM   #6
slam59
Thank guys, keep the pics coming.
Old 03-24-2012, 11:38 PM   #7
rfmaster
rfmaster's Avatar
I had good results using POR-15 Engine Enamel. One quart (black or chevy orange) is more than enough to do one engine. Stuff goes on with a brush which allows for a greater control vs. rattle can. Once paint dries it maintains that wet look.
For '74 model year truck it you should use chevy orange, but as my Elmer used to say engines are color blind.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 03-25-2012, 01:49 AM   #8
3r!c84
Badass
3r!c84's Avatar
Mine on the stand
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-25-2012, 02:55 AM   #9
rfmaster
rfmaster's Avatar
Well, I'll have to oblige...
This engine came from a swap meet - very cheap. It is 3970010 block circa 1971. My machinist indicated that this is probably one of the last higher Nickel content blocks GM produced. To cut machining cost GM reduced Nickel levels in mid 70's into the 80's.
Engine is mounted on the stand - starting the tear down. Lots of oil crud indicating infrequent oil changes.
and this is a result of infrequent oil changes - #3 connecting rod bearings has spun rendering Crankshaft unrepairable! The 4-bolt main block however is in good shape along with Nodular main caps.
Skipping ahead..
Painting the Engine (350SBC) - POR-15 Engine Enamel (Chevy Orange)
Mounted on the test stand for cam break-in
Just dropped in in its new home.
//RF
"The Beast"
Old 03-25-2012, 12:47 PM   #10
INSIDIOUS '86
INSIDIOUS '86's Avatar
I like the contrast of the orange black and polished aluminum
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-25-2012, 05:07 PM   #11
slam59
Man all of yours look cool man! I hope to be having my friend/mechanic start this week on mine.
Thread Tools
Display Modes
