03-25-2012, 12:32 PM | #1 |
Hood pull????????- help needed
How do you get your hood open if the hood pull cable is broke? Thanks,buddy
03-25-2012, 01:01 PM | #2 |
Re: Hood pull????????- help needed
Take your grill off then that will allow for access to the latch so you can pop it.
03-25-2012, 01:07 PM | #3 |
idk on these trucks but if you lay under it you can usually get too it also
03-25-2012, 01:50 PM | #4 | |||
Canadian Trucker
This works
2020 Silverado Trail Boss - 6.2/10spd |
03-25-2012, 04:31 PM | #5 |
Hey, it is a 1984 chev. Thanks,buddy
03-25-2012, 05:38 PM | #6 |
Let us know how you get it open.
03-25-2012, 05:42 PM | #7 |
Take a piece of wood that is thin enough to fit between the hood and rad support. Pry right under the center of the hood until you can see the hood latch bolts. You should be able to get to the bolts with an extension and maybe a swivel, if necessary. Unbolt the latch and open your hood. I've done it multiple times when my latch broke.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
03-26-2012, 01:37 AM | #8 |
Do it like the guy that was caught taking my parts.
1/4" steel rod,18"long.Make a 90*bend,1/2 "from the end,and another 90* bend,2&1/2",from the first. slide the bent end between the spring that pushes the hood up,and the latch,until it is behind the latch. While pulling some tension,push the rod toward the driver's side,and it will release the latch. After the guy was arrested,I decided it would be a useful item,so I made one,too.It really works well.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
03-26-2012, 04:55 AM | #9 |
I just had to make a hook out of 1/16" round stock and reach around up in there blind till I hooked the pull. It is frustrating. I have had to do it twice.
Posted via Mobile Device |
03-26-2012, 09:44 AM | #10 | |
03-26-2012, 12:21 PM | #11 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-28-2012, 12:54 AM | #12 |
grs,I will post pics tomorrow,of the tool,and how to use it.
Yes,the guy went to jail(gladly!)as I noted in my thread,"Dist Rotor Mystery". He is scheduled for trial in April,for theft,in excess of $100(felony),burglary,and criminal tresspass. It is NOT his first time,so it's gonna go hard for him.
03-28-2012, 11:32 AM | #13 | |
03-28-2012, 04:32 PM | #14 |
Here are pics of the tool,and how it is positioned.Note that it slides in UNDER the cable,then loops behind the latch.
Once it's in position,push the rod toward the driver's side(keep your hand close to the hood,and the other hand on the end),and it will release the latch. It might take a couple of tries,(and come in from passengers side,at 45 * angle,between the latch,and the big spring),but you'll be able to do it quite easily,after that.
03-28-2012, 05:31 PM | #15 |
I will try to make one. I hope there is no one on this site that makes one, and starts to steal parts off our trucks.
03-28-2012, 06:41 PM | #16 |
LOL! I'm not worried about it,anymore! I'm making an alarm that trips the horn(I have air horns)when I flip a switch inside the cab.As soon as the latch is released,with the switch ON,the air horns go off!
If that fails to stop them,the .380 WILL !! With the switch OFF,I can open the hood normally.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? Last edited by jhngardner367; 03-28-2012 at 06:42 PM. Reason: fat fingers |
03-28-2012, 07:14 PM | #17 | |
03-28-2012, 10:54 PM | #18 |
They're just some cheapies I bought at Harbor Freight,for $20. But they're louder than stock horns! I'll get a pic for you,tomorrow.They came with the relay,dual trumpets,compressor,wiring,and instructions.
03-29-2012, 04:44 PM | #19 |
Hey grs,here are the pics of the air horns & compressor.As I said ,they're just cheapies,but they can DEFINITELY be heard!LOL
03-29-2012, 07:13 PM | #20 | |
Thread Tools | |
Display Modes | |
