Old 05-05-2003, 11:35 PM   #1
ibjoker69
hahaha
turbo 400?
On the Th 400 were does it pick up the power for the kickdown? Mine is running from the coil pos side. Is that not 6.6 volts there and should it be 12v? thanks Joker.
69lwb, 29 A coupe hotrod, 55 chevy hardtop,
ibjoker69 is offline   Reply With Quote
Old 05-05-2003, 11:49 PM   #2
wHATANERD
wHATANERD's Avatar
The kickdown switch should be connected to 12 volts, I recently connected my switch, and every thins seems to be working great.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 05-06-2003, 01:15 AM   #3
crazy4chevs
crazy4chevs's Avatar
Im not shure but i thought it shared the wiper circut power by a factory adapter harness.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 05-06-2003, 04:36 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
You need a keyed ignition source that is not on the circuit for the coil.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-06-2003, 08:42 AM   #5
JimKshortstep4x4
Talking
It piggy backs on the switched ignition terminal in the fuse panel
if there is something there already, (like a tach).
Jim
Thread Tools
Display Modes
