04-03-2012, 06:29 PM | #1 |
ad gmc rad preesue valve fix
as many of you know the gmc rad differs from the chevy in that the pressure releaf valve is mounted in the rad and not attached to the cap. i have looked and could not find a replacement anywhere. here is a quick fix if you plan on keeping your stock radiator. first pick shows the what we are starting with.
second is the valve cover removed. there will be a valve in ther mine was removed previous to try to find a new one. the third pic is of the new radiator cap i got at the auto store. if i remember correctly it was for a 79 chevy small block. you need to drill out the rivet in the center of the cap. i would sujest drilling it out from the top not the underside where the valve it at. fourth pic shows what it should look like after you drill the rivet out. the fifth pic shows the parts you will need from the recently butchered radiator cap.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
04-03-2012, 06:40 PM | #2 |
Re: ad gmc rad preesue valve fix
now we will install the valve in the rad. make sure you take note of wthich way the rad cap was taken appart as you need to install the valve the way it would go into the rad normally. the spring will face out twards the cover. you will not the spring fits nicely in the cover. make sure you get a new o ring to seal the cover or it will leak/spray colant all over the place. and lastley install the cover and snap ring. now you done. this little fix cost me under $10.00. works great. i add a recovery tank and hose like on a newer truck so i wouldn't lose any colant.
04-04-2012, 09:33 PM | #3 |
30 views and no one has a comment. i'm shocked. come on good or bad lets hear it.
04-04-2012, 11:30 PM | #4 |
When the rad om my 55 1st series was 50 years old I bought her a new rad and hope it only lasts for twenty five years, as that is the only guarentee I want!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-05-2012, 11:18 AM | #5 |
what was the pressure rating on the cap you pulled the spring from? looks like it might have been a 16lb cap. You old honeycomb radiator won't like at all. neither will your heater core. I think you find these old system had like 6lbs.
might depend on the new installed height of the spring though. I'd get one of those pump pressure testers and check it. |
04-05-2012, 12:48 PM | #6 | |
04-05-2012, 01:47 PM | #7 |
it is a 12 pound cap. i talked with a local rad guy and he said that it would be fine. the rad will handle it as well as the heater core. they haven't made rads or cores any different in the 70's as the did in the 50's. mine has been working fine no leaks or any problems.
04-05-2012, 02:24 PM | #8 |
It's not that the core is different. It's that the metal has been oxidizing for a much longer timeframe and the core is that much closer to failing. Hey, if it works then it works. But not everyone gets lucky.
04-05-2012, 08:14 PM | #9 |
that looks like a honeycomb core to me, and yes they did change the way the make radiators. sometime around 1960 they stopped the honeycomb deal and went to tube and fin construction which is still use today. I'd be checking around on this if I were you. Honeycomb cores don't like much pressure, especially old honeycombs
04-06-2012, 07:39 AM | #10 |
i guess that is why the old timer at the rad shop said i could use my rad with the smallblock i have. my rad is not a honeycomb. it is a tube and fin. so is the heater core. i guess i got really luck that they are not the honeycomb ones. thanks for the info.
04-06-2012, 09:32 AM | #11 |
COOL and easy too.
04-08-2012, 09:34 PM | #12 |
Hollister Road Co.
I think the ingenuity of your fix would be appreciated more over at Stovebolt.com. Its geared more toward original restoration than this site is.
Thread Tools | |
Display Modes | |
