Old 04-04-2012, 01:09 AM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
gauge cluster light problem
i took the lights out of my gauge cluster when i took it apart to clean it, now some of them are loose when you turn them to lock them in nd they keep falling out, any ideas how to make them stay in?
1972BackInBlackC10 is offline   Reply With Quote
Old 04-04-2012, 01:50 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: gauge cluster light problem
Replace them.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-04-2012, 01:54 AM   #3
1972BackInBlackC10
id just buy a different cluster then, the nearest wrecker is an hr away if im going to make that trip it has to be for something more than 5 bucks lol was hoping i could them to twist out some how
Old 04-04-2012, 03:00 AM   #4
BLE 'BURBAN
All you need do is hit up your local NAPA AUTO PARTS or Carquest or whatever you've got over there in Canada (yeah I said OVER THERE & not UP THERE... I'm next door to ya in Alaska) and get some replacement sockets like these shown below.
ECH LS6500
Attributes
Lamp Socket Hole Size : 1/2"
Socket Bulb # : 168, 194
Part: ECH LS6501
Attributes
Lamp Socket Hole Size : 5/8"
and get the 168 bulbs as they're a bit brighter than the 194's
Old 04-04-2012, 03:06 AM   #5
1972BackInBlackC10
we dont have a napa here, do you think im talking about the bulbs? im refering to the plastic peice the bulb goes in that goes on the back of the gauge cluster they are black
Old 04-04-2012, 03:21 AM   #6
BLE 'BURBAN
Had to edit my post up above refresh and re-read it please. These sockets should be readily available at any of the bigger auto parts stores. They may have to cross referance the part numbers I provided you (NAPA's #'s)
I'm pretty conident you'll find them.
Good luck and have fun,
Dave
Old 04-04-2012, 03:27 AM   #7
1972BackInBlackC10
yea all we have in town here is canadian tire and they arent very useful, we do have a couple other parts places though i could try, i didnt think of this before but maybe i could possibly bend the two metal tabs out a bit
Old 04-04-2012, 10:04 AM   #8
'79squared
'79squared's Avatar
Have you tried bending the connection tabs up a bit to create more pressure when twisted in? I bet that would hold them tighter.
1979 SWB 350/350
'79squared is offline   Reply With Quote
Old 04-04-2012, 02:52 PM   #9
1972BackInBlackC10
yea thats what im going to try
Old 04-04-2012, 09:25 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
bend them , and check for the little raised lock dot around the hole
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-05-2012, 01:34 PM   #11
bilfman
bilfman's Avatar
I've bent mine and it worked perfect.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-05-2012, 01:41 PM   #12
JRANGER
JRANGER's Avatar
bent mine too....Also check the circuit board to see if any of the connections are broke...I had to drop a bead of solder on my right blinker to fix the connection
JRANGER is offline   Reply With Quote
Thread Tools
Display Modes
