Old 04-08-2012, 04:36 PM   #1
mooseknuckles
mooseknuckles's Avatar
drive shaft??
just wondering what I would need for a yolk for my 4l80e? is it the same as a th400?....and how much longer is the 4l80e trans than a 700r4 trans?
mooseknuckles is offline   Reply With Quote
Old 04-08-2012, 11:38 PM   #2
code4
Re: drive shaft??
yes, same as t400 as far as spine. not sure how much longer it is.
code4 is offline   Reply With Quote
Old 04-09-2012, 12:44 PM   #3
83 Silverado
83 Silverado's Avatar
Re: drive shaft??
If you go on the TCI trans site you can find a chart with the langths http://www.tciauto.com/tc/trans-dim
83 Silverado is offline   Reply With Quote
Old 04-09-2012, 04:41 PM   #4
mooseknuckles
Re: drive shaft??
cool link thanks man.
Old 04-09-2012, 07:46 PM   #5
nacho55
Re: drive shaft??
After you find out the spline count and length you need hit the junkyard as I found tons of good ones at my local pickapart when I was scrounging for my driveline setup, even with having it shorten and re-balanced I have less than 150.. you almost can't get a yoke for that. And those are the big 32spline ones that are pretty tough and most of the ones I found were like new or just had a little surface rust that comes off with steel wool or sandpaper.
nacho55 is offline   Reply With Quote
Old 04-09-2012, 08:07 PM   #6
mooseknuckles
Re: drive shaft??
think its a 32 spline...how do I find the length?
Old 04-09-2012, 08:25 PM   #7
nacho55
Re: drive shaft??
Not sure but if it's like the one use which was out of a later truck it was 4-5" if I remember there's not alot of differnt sizes so you can't go to wrong if your a little long. The yoke can be shortened too. but the important thing is that when you install the yoke into the transmission you have 3/4" to -1" of travel for the yoke to slide in and out. That's how the driveline shops measure for it so it doesn't bottom out. Do you have a drive shaft your trying to use or? If not just find the yoke and start from there.
Old 04-09-2012, 11:28 PM   #8
clinebarger
Re: drive shaft??
Are you using a bolt-on yolk or a slip yoke?
clinebarger is offline   Reply With Quote
Old 04-10-2012, 08:05 AM   #9
mooseknuckles
Re: drive shaft??
slip yolk...I don't have anything right now.....
Old 04-10-2012, 02:36 PM   #10
nacho55
Re: drive shaft??
Moose,
Are you planning on buying new yoke and getting a driveline built? If your searching for yokes new try to match it with the same size ujoint that your rear takes it will save you the trouble of having two different ones when it comes time to replacing ,
Old 04-10-2012, 03:37 PM   #11
mooseknuckles
Re: drive shaft??
Moose,
yeah...gotta buy one..apparently there's 3 or 4 different ones, and I can't get an answer on anything..I'm using the stock two piece driveshaft so it may have to be shortened.....
Old 04-10-2012, 07:49 PM   #12
nacho55
Re: drive shaft??
Check the output shaft of the transmission, if it has a threaded hole it was a bolt on yoke and you will need a special one, if not threaded you can just order a long 32spline with the ujoints that match your current driveline but your most likely going to have to shorten one of you lines because I think the 4l80e is longer that the 700r4 and definitely longer than a th350 or 400. This is also dependant on your engine placement. Have you measured what driveline you have now to see how close it is?
Old 04-10-2012, 08:14 PM   #13
mooseknuckles
Re: drive shaft??
I just did a rough measure and thought it might be close...but I'll have to check again...the trans def has a hole in the output shaft.....
Old 04-10-2012, 08:19 PM   #14
clinebarger
Re: drive shaft??
Ive never seen a 4L80E have a slip yoke, Unless someone put a TH400 output shaft in it.....Use a Bolt-on yoke....You already have a Slip Yoke in your drive shaft (circle)
Old 04-10-2012, 08:26 PM   #15
mooseknuckles
Re: drive shaft??
...so where do i find one of those?
Old 04-10-2012, 10:48 PM   #16
clinebarger
Re: drive shaft??
Im curious to know why its missing, Remove the tailhousing & make sure the O-ring is there...If it is Replace the O-ring.
If the O- ring groove/seat for the bolt-on yolk has been machined off, Ive seen ouput shafts that someone took a grinder to them also.......You have to run a slip yoke.
Point is....Check out whats going on before you buy parts.
Ive thrown Bolt-on TH400/4L80E yolks away because I was tired of tripping over them. The TH400/4L80E slip yoke is rare in good used shape.
Hit some local transmission shops after you know whats going on.
Old 04-11-2012, 06:01 AM   #17
mooseknuckles
Re: drive shaft??
so..bolt on or slip?
Old 04-11-2012, 09:46 PM   #18
clinebarger
Re: drive shaft??
Just from outside looks & the fact 4L80Es had a bolt-on yolk......I would say Bolt-on, I was just recommending checking before buying.
Old 04-17-2012, 11:20 PM   #19
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: drive shaft??
http://ls1tech.com/forums/automatic-...uestion-2.html
Here is some more conversation regarding this ... and I'm not yolking either!
lol!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-17-2012, 11:28 PM   #20
Gordonr1973
Home Built '87
Re: drive shaft??
Not really sure either what I am going to go with, just didn't like the driveshaft shop quoting me $500 to build me a new drive shaft from scratch!
A few more links, not sure which applies to your situation with the two-piece.
http://www.chevyhiperformance.com/te.../photo_01.html
http://www.ebay.com/itm/NEW-DRIVESHA...sories&vxp=mtr
http://www.summitracing.com/parts/IED-SY-400-1310
http://www.performancetrucks.net/for...o-i-do-486687/
Gordon
Old 04-18-2012, 09:53 PM   #21
Dustytrix
Re: drive shaft??
I have a bolt on type that has the u-joint bolt on clamps. They are missing tho, let me know if you think you can use it.
Dustytrix is offline   Reply With Quote
Old 04-19-2012, 09:47 AM   #22
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: drive shaft??
Not that it means anything, but my 4L80E came with a factory slip yolk.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Thread Tools
Display Modes
